[Swift-user] queue problem?
Justin M Wozniak wozniak at mcs.anl.gov
Mon May 16 12:09:24 CDT 2011
That's probably a perms thing, I just reapplied the permissions, please
try again.
On Mon, 16 May 2011, Sheri Mickelson wrote:
> Hi Justin,
> I'm getting this error when swift tries to run:
> Exception in thread "main" java.lang.NoClassDefFoundError:
> org/griphyn/vdl/karajan/Loader
> Caused by: java.lang.ClassNotFoundException: org.griphyn.vdl.karajan.Loader
> 	at java.net.URLClassLoader$1.run(URLClassLoader.java:202)
> 	at java.security.AccessController.doPrivileged(Native Method)
> 	at java.net.URLClassLoader.findClass(URLClassLoader.java:190)
> 	at java.lang.ClassLoader.loadClass(ClassLoader.java:307)
> 	at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:301)
> 	at java.lang.ClassLoader.loadClass(ClassLoader.java:248)
> Could not find the main class: org.griphyn.vdl.karajan.Loader.  Program will
> exit.
> -Sheri
> Justin M Wozniak wrote:
>> Let's go with my trunk-based installation in the location below for now. I
>> tried testing this again over the weekend but did not get through the
>> queue.  I have already set up the additional logging in this installation.
>> /homes/wozniak/Public/cog/modules/swift/dist/swift-svn/bin/swift
>>     Justin
>> On Fri, 13 May 2011, Sheri Mickelson wrote:
>>> Here's the log file.
>>> This is the first time I'm running this version of swift on fusion.  I had
>>> done my development work with this swift version on an mcs compute
>>> machine.
>>> -Sheri
>>>> Hello
>>>>     Can you send the log for this run?
>>>>     Is this a new issue that appeared after an update?
>>>>     Also, in any future runs regarding this issue, please add
>>>> log4j.logger.org.globus.cog.abstraction.coaster.service.job.manager.BlockQueueProcessor
>>>> = DEBUG
>>>> (one line) to your etc/log4j.properties file.
>>>>     Thanks
>>>>     Justin
>>>>> I'm running into a problem running swift version 0.92.1 on fusion with
>>>>> coasters.
>>>>> This is the error I'm seeing:
>>>>> Progress:  Selecting site:168  Submitted:23  Active:2
>>>>> Progress:  Selecting site:168  Submitted:23  Active:1  Checking status:1
>>>>> Progress:  Selecting site:167  Stage in:1  Submitted:22  Active:2
>>>>> Finished successfully:1
>>>>> queuedsize > 0 but no job dequeued. Queued: {}
>>>>> java.lang.Throwable
>>>>>     at
>>>>> org.globus.cog.abstraction.coaster.service.job.manager.BlockQueueProcessor.requeueNonFitting(BlockQueueProcessor.java:252)
>>>>>     at
>>>>> org.globus.cog.abstraction.coaster.service.job.manager.BlockQueueProcessor.updatePlan(BlockQueueProcessor.java:520)
>>>>>     at
>>>>> org.globus.cog.abstraction.coaster.service.job.manager.BlockQueueProcessor.run(BlockQueueProcessor.java:109)
>>>>> java.lang.Throwable
>>>>>     at
>>>>>     at
>>>>>     at
>>>>> Shutting down worker
>>>>> And here's my sites file:
>>>>> <config>
>>>>> <pool handle="fusion">
>>>>>  <execution jobmanager="local:pbs" provider="coaster" url="none"/>
>>>>>  <profile namespace="globus" key="maxtime">3600</profile>
>>>>>  <profile namespace="globus" key="workersPerNode">1</profile>
>>>>>  <profile namespace="globus" key="slots">1</profile>
>>>>>  <profile namespace="globus"  key="nodeGranularity">4</profile>
>>>>>  <profile namespace="globus" key="maxNodes">2</profile>
>>>>>  <profile namespace="globus" key="queue">batch</profile>
>>>>>  <profile namespace="karajan" key="jobThrottle">0.23</profile>
>>>>>  <profile namespace="karajan" key="initialScore">10000</profile>
>>>>>  <profile namespace="globus" key="project">parvis</profile>
>>>>>  <profile namespace="globus"  key="lowOverAllocation">100</profile>
>>>>>  <profile namespace="globus"  key="highOverAllocation">100</profile>
>>>>>  <filesystem provider="local"/>
>>>>>  <workdirectory>/fusion/gpfs/home/mickelso/amwg-swift/swift/</workdirectory>
>>>>> </pool>
>>>>> </config>
>>>>> Do you know what might be causing this?
>>>>> Thanks, Sheri
>>>>> _______________________________________________
>>>>> Swift-user mailing list
>>>>> Swift-user at ci.uchicago.edu
>>>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
Justin M Wozniak
More information about the Swift-user mailing list
