[Swift-user] queue problem?
Sheri Mickelson
mickelso at mcs.anl.gov
Mon May 16 13:52:48 CDT 2011
I'm seeing a different error now:
mapper.existing() returned a path [3] that it cannot subsequently map
It starts up, but dies shortly after that. I attached the log file.
-Sheri
Justin M Wozniak wrote:
> That's probably a perms thing, I just reapplied the permissions, please
> try again.
> On Mon, 16 May 2011, Sheri Mickelson wrote:
>> Hi Justin,
>> I'm getting this error when swift tries to run:
>> Exception in thread "main" java.lang.NoClassDefFoundError:
>> org/griphyn/vdl/karajan/Loader
>> Caused by: java.lang.ClassNotFoundException:
>> org.griphyn.vdl.karajan.Loader
>> at java.net.URLClassLoader$1.run(URLClassLoader.java:202)
>> at java.security.AccessController.doPrivileged(Native Method)
>> at java.net.URLClassLoader.findClass(URLClassLoader.java:190)
>> at java.lang.ClassLoader.loadClass(ClassLoader.java:307)
>> at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:301)
>> at java.lang.ClassLoader.loadClass(ClassLoader.java:248)
>> Could not find the main class: org.griphyn.vdl.karajan.Loader.
>> Program will exit.
>> -Sheri
>>> Let's go with my trunk-based installation in the location below for
>>> now. I tried testing this again over the weekend but did not get
>>> through the queue. I have already set up the additional logging in
>>> this installation.
>>> /homes/wozniak/Public/cog/modules/swift/dist/swift-svn/bin/swift
>>> Justin
>>> On Fri, 13 May 2011, Sheri Mickelson wrote:
>>>> Here's the log file.
>>>> This is the first time I'm running this version of swift on fusion.
>>>> I had done my development work with this swift version on an mcs
>>>> compute machine.
>>>> -Sheri
>>>>> Hello
>>>>> Can you send the log for this run?
>>>>> Is this a new issue that appeared after an update?
>>>>> Also, in any future runs regarding this issue, please add
>>>>> log4j.logger.org.globus.cog.abstraction.coaster.service.job.manager.BlockQueueProcessor
>>>>> = DEBUG
>>>>> (one line) to your etc/log4j.properties file.
>>>>> Thanks
>>>>> Justin
>>>>>> I'm running into a problem running swift version 0.92.1 on fusion
>>>>>> with coasters.
>>>>>> This is the error I'm seeing:
>>>>>> Progress: Selecting site:168 Submitted:23 Active:2
>>>>>> Progress: Selecting site:168 Submitted:23 Active:1 Checking
>>>>>> status:1
>>>>>> Progress: Selecting site:167 Stage in:1 Submitted:22 Active:2
>>>>>> Finished successfully:1
>>>>>> queuedsize > 0 but no job dequeued. Queued: {}
>>>>>> java.lang.Throwable
>>>>>> at
>>>>>> org.globus.cog.abstraction.coaster.service.job.manager.BlockQueueProcessor.requeueNonFitting(BlockQueueProcessor.java:252)
>>>>>> at
>>>>>> org.globus.cog.abstraction.coaster.service.job.manager.BlockQueueProcessor.updatePlan(BlockQueueProcessor.java:520)
>>>>>> at
>>>>>> org.globus.cog.abstraction.coaster.service.job.manager.BlockQueueProcessor.run(BlockQueueProcessor.java:109)
>>>>>> java.lang.Throwable
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> Shutting down worker
>>>>>> And here's my sites file:
>>>>>> <config>
>>>>>> <pool handle="fusion">
>>>>>> <execution jobmanager="local:pbs" provider="coaster" url="none"/>
>>>>>> <profile namespace="globus" key="maxtime">3600</profile>
>>>>>> <profile namespace="globus" key="workersPerNode">1</profile>
>>>>>> <profile namespace="globus" key="slots">1</profile>
>>>>>> <profile namespace="globus" key="nodeGranularity">4</profile>
>>>>>> <profile namespace="globus" key="maxNodes">2</profile>
>>>>>> <profile namespace="globus" key="queue">batch</profile>
>>>>>> <profile namespace="karajan" key="jobThrottle">0.23</profile>
>>>>>> <profile namespace="karajan" key="initialScore">10000</profile>
>>>>>> <profile namespace="globus" key="project">parvis</profile>
>>>>>> <profile namespace="globus" key="lowOverAllocation">100</profile>
>>>>>> <profile namespace="globus" key="highOverAllocation">100</profile>
>>>>>> <filesystem provider="local"/>
>>>>>> <workdirectory>/fusion/gpfs/home/mickelso/amwg-swift/swift/</workdirectory>
>>>>>> </pool>
>>>>>> </config>
>>>>>> Do you know what might be causing this?
>>>>>> Thanks, Sheri
>>>>>> _______________________________________________
>>>>>> Swift-user mailing list
>>>>>> Swift-user at ci.uchicago.edu
>>>>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20110516/47bda234/attachment.ksh>
More information about the Swift-user
