[Swift-user] queue problem?
Sheri Mickelson
mickelso at mcs.anl.gov
Mon May 16 09:58:15 CDT 2011
Hi Justin,
I'm getting this error when swift tries to run:
Exception in thread "main" java.lang.NoClassDefFoundError: org/griphyn/vdl/karajan/Loader
Caused by: java.lang.ClassNotFoundException: org.griphyn.vdl.karajan.Loader
at java.net.URLClassLoader$1.run(URLClassLoader.java:202)
at java.security.AccessController.doPrivileged(Native Method)
at java.net.URLClassLoader.findClass(URLClassLoader.java:190)
at java.lang.ClassLoader.loadClass(ClassLoader.java:307)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:301)
at java.lang.ClassLoader.loadClass(ClassLoader.java:248)
Could not find the main class: org.griphyn.vdl.karajan.Loader. Program will exit.
-Sheri
Justin M Wozniak wrote:
> Let's go with my trunk-based installation in the location below for now.
> I tried testing this again over the weekend but did not get through the
> queue. I have already set up the additional logging in this installation.
> /homes/wozniak/Public/cog/modules/swift/dist/swift-svn/bin/swift
> Justin
> On Fri, 13 May 2011, Sheri Mickelson wrote:
>> Here's the log file.
>> This is the first time I'm running this version of swift on fusion. I
>> had done my development work with this swift version on an mcs compute
>> machine.
>> -Sheri
>>> Hello
>>> Can you send the log for this run?
>>> Is this a new issue that appeared after an update?
>>> Also, in any future runs regarding this issue, please add
>>> log4j.logger.org.globus.cog.abstraction.coaster.service.job.manager.BlockQueueProcessor
>>> = DEBUG
>>> (one line) to your etc/log4j.properties file.
>>> Thanks
>>> Justin
>>>> I'm running into a problem running swift version 0.92.1 on fusion
>>>> with coasters.
>>>> This is the error I'm seeing:
>>>> Progress: Selecting site:168 Submitted:23 Active:2
>>>> Progress: Selecting site:168 Submitted:23 Active:1 Checking
>>>> status:1
>>>> Progress: Selecting site:167 Stage in:1 Submitted:22 Active:2
>>>> Finished successfully:1
>>>> queuedsize > 0 but no job dequeued. Queued: {}
>>>> java.lang.Throwable
>>>> at
>>>> org.globus.cog.abstraction.coaster.service.job.manager.BlockQueueProcessor.requeueNonFitting(BlockQueueProcessor.java:252)
>>>> at
>>>> org.globus.cog.abstraction.coaster.service.job.manager.BlockQueueProcessor.updatePlan(BlockQueueProcessor.java:520)
>>>> at
>>>> org.globus.cog.abstraction.coaster.service.job.manager.BlockQueueProcessor.run(BlockQueueProcessor.java:109)
>>>> java.lang.Throwable
>>>> at
>>>> at
>>>> at
>>>> Shutting down worker
>>>> And here's my sites file:
>>>> <config>
>>>> <pool handle="fusion">
>>>> <execution jobmanager="local:pbs" provider="coaster" url="none"/>
>>>> <profile namespace="globus" key="maxtime">3600</profile>
>>>> <profile namespace="globus" key="workersPerNode">1</profile>
>>>> <profile namespace="globus" key="slots">1</profile>
>>>> <profile namespace="globus" key="nodeGranularity">4</profile>
>>>> <profile namespace="globus" key="maxNodes">2</profile>
>>>> <profile namespace="globus" key="queue">batch</profile>
>>>> <profile namespace="karajan" key="jobThrottle">0.23</profile>
>>>> <profile namespace="karajan" key="initialScore">10000</profile>
>>>> <profile namespace="globus" key="project">parvis</profile>
>>>> <profile namespace="globus" key="lowOverAllocation">100</profile>
>>>> <profile namespace="globus" key="highOverAllocation">100</profile>
>>>> <filesystem provider="local"/>
>>>> <workdirectory>/fusion/gpfs/home/mickelso/amwg-swift/swift/</workdirectory>
>>>> </pool>
>>>> </config>
>>>> Do you know what might be causing this?
>>>> Thanks, Sheri
>>>> _______________________________________________
>>>> Swift-user mailing list
>>>> Swift-user at ci.uchicago.edu
>>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
More information about the Swift-user
