[Swift-user] queue problem?
Justin M Wozniak wozniak at mcs.anl.gov
Mon May 16 09:05:14 CDT 2011
Let's go with my trunk-based installation in the location below for now.
I tried testing this again over the weekend but did not get through the
queue.  I have already set up the additional logging in this installation.
/homes/wozniak/Public/cog/modules/swift/dist/swift-svn/bin/swift
 	Justin
On Fri, 13 May 2011, Sheri Mickelson wrote:
> Here's the log file.
> This is the first time I'm running this version of swift on fusion.  I had
> done my development work with this swift version on an mcs compute machine.
> -Sheri
> Justin M Wozniak wrote:
>> Hello
>>     Can you send the log for this run?
>>     Is this a new issue that appeared after an update?
>>     Also, in any future runs regarding this issue, please add
>> log4j.logger.org.globus.cog.abstraction.coaster.service.job.manager.BlockQueueProcessor
>> = DEBUG
>> (one line) to your etc/log4j.properties file.
>>     Thanks
>>     Justin
>>> I'm running into a problem running swift version 0.92.1 on fusion with
>>> coasters.
>>> This is the error I'm seeing:
>>> Progress:  Selecting site:168  Submitted:23  Active:2
>>> Progress:  Selecting site:168  Submitted:23  Active:1  Checking status:1
>>> Progress:  Selecting site:167  Stage in:1  Submitted:22  Active:2
>>> Finished successfully:1
>>> queuedsize > 0 but no job dequeued. Queued: {}
>>> java.lang.Throwable
>>>     at
>>> org.globus.cog.abstraction.coaster.service.job.manager.BlockQueueProcessor.requeueNonFitting(BlockQueueProcessor.java:252)
>>>     at
>>> org.globus.cog.abstraction.coaster.service.job.manager.BlockQueueProcessor.updatePlan(BlockQueueProcessor.java:520)
>>>     at
>>> org.globus.cog.abstraction.coaster.service.job.manager.BlockQueueProcessor.run(BlockQueueProcessor.java:109)
>>> java.lang.Throwable
>>>     at
>>>     at
>>>     at
>>> Shutting down worker
>>> And here's my sites file:
>>> <config>
>>> <pool handle="fusion">
>>>  <execution jobmanager="local:pbs" provider="coaster" url="none"/>
>>>  <profile namespace="globus" key="maxtime">3600</profile>
>>>  <profile namespace="globus" key="workersPerNode">1</profile>
>>>  <profile namespace="globus" key="slots">1</profile>
>>>  <profile namespace="globus"  key="nodeGranularity">4</profile>
>>>  <profile namespace="globus" key="maxNodes">2</profile>
>>>  <profile namespace="globus" key="queue">batch</profile>
>>>  <profile namespace="karajan" key="jobThrottle">0.23</profile>
>>>  <profile namespace="karajan" key="initialScore">10000</profile>
>>>  <profile namespace="globus" key="project">parvis</profile>
>>>  <profile namespace="globus"  key="lowOverAllocation">100</profile>
>>>  <profile namespace="globus"  key="highOverAllocation">100</profile>
>>>  <filesystem provider="local"/>
>>>  <workdirectory>/fusion/gpfs/home/mickelso/amwg-swift/swift/</workdirectory>
>>> </pool>
>>> </config>
>>> Do you know what might be causing this?
>>> Thanks, Sheri
>>> _______________________________________________
>>> Swift-user mailing list
>>> Swift-user at ci.uchicago.edu
>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
Justin M Wozniak
More information about the Swift-user mailing list
