[Swift-user] Adding :bigmem to node count
Justin M Wozniak wozniak at mcs.anl.gov
Fri Mar 18 14:16:37 CDT 2011
Hello
 	Actually, it looks like there may be a queue for bigmem jobs, is
that what you want to use?  If so, you would just modify the queue profile
entry in sites.xml .
 	Justin
On Sun, 13 Mar 2011, Justin M Wozniak wrote:
> I'll take a look at this- it will probably be a small CoG feature addition.
> On Sat, 12 Mar 2011, Sheri Mickelson wrote:
>> Hi Mike,
>> It's for fusion and I'm running with swift-r3967.
>> Thanks, Sheri
>> Michael Wilde wrote:
>>> Sheri, I am not yet sure, but I think we'll need to add a feature in Swift
>>> to enable this specification to be passed down to qsub. That should be
>>> doable fairly soon; I had to do something similar to run on Cray XE/XT
>>> systems, which I did based on Swift 0.92.
>>> What machine is this for, and which Swift release or build are you
>>> running?
>>> In the meantime, a solution you could use more immediately would be to run
>>> with manual/persistent coasters, where you could specify your own qsub.
>>> This works right now but requires some wrapper scripting that is not yet
>>> packaged or sufficiently documented, so thats a route that also requires
>>> some work from you and/or us.
>>> I know Justin is working with you, so we should all coordinate and
>>> hopefully we can resolve this soon for you.
>>> - Mike
>>> ----- Original Message -----
>>>> Hi,
>>>> To run a job without swift I need to specify "-l nodes=2:bigmem" in
>>>> either my qsub command or add it
>>>> to my run script. How do I tell swift to add ":bigmem" to the node
>>>> total?
>>>> Thanks, Sheri
>>>> _______________________________________________
>>>> Swift-user mailing list
>>>> Swift-user at ci.uchicago.edu
>>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
Justin M Wozniak
More information about the Swift-user mailing list
