[Swift-user] Adding :bigmem to node count
Justin M Wozniak wozniak at mcs.anl.gov
Sun Mar 13 17:17:55 CDT 2011
I'll take a look at this- it will probably be a small CoG feature
addition.
On Sat, 12 Mar 2011, Sheri Mickelson wrote:
> Hi Mike,
> It's for fusion and I'm running with swift-r3967.
> Thanks, Sheri
> Michael Wilde wrote:
>> Sheri, I am not yet sure, but I think we'll need to add a feature in Swift
>> to enable this specification to be passed down to qsub. That should be
>> doable fairly soon; I had to do something similar to run on Cray XE/XT
>> systems, which I did based on Swift 0.92.
>> What machine is this for, and which Swift release or build are you running?
>> In the meantime, a solution you could use more immediately would be to run
>> with manual/persistent coasters, where you could specify your own qsub.
>> This works right now but requires some wrapper scripting that is not yet
>> packaged or sufficiently documented, so thats a route that also requires
>> some work from you and/or us.
>> I know Justin is working with you, so we should all coordinate and
>> hopefully we can resolve this soon for you.
>> - Mike
>> ----- Original Message -----
>>> Hi,
>>> To run a job without swift I need to specify "-l nodes=2:bigmem" in
>>> either my qsub command or add it
>>> to my run script. How do I tell swift to add ":bigmem" to the node
>>> total?
>>> Thanks, Sheri
>>> _______________________________________________
>>> Swift-user mailing list
>>> Swift-user at ci.uchicago.edu
>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
Justin M Wozniak
More information about the Swift-user mailing list
