[Swift-user] Adding :bigmem to node count
Sheri Mickelson mickelso at mcs.anl.gov
Sat Mar 12 11:01:30 CST 2011
Hi Mike,
It's for fusion and I'm running with swift-r3967.
Thanks, Sheri
Michael Wilde wrote:
> Sheri, I am not yet sure, but I think we'll need to add a feature in Swift to enable this specification to be passed down to qsub. That should be doable fairly soon; I had to do something similar to run on Cray XE/XT systems, which I did based on Swift 0.92.
> What machine is this for, and which Swift release or build are you running?
> In the meantime, a solution you could use more immediately would be to run with manual/persistent coasters, where you could specify your own qsub. This works right now but requires some wrapper scripting that is not yet packaged or sufficiently documented, so thats a route that also requires some work from you and/or us.
> I know Justin is working with you, so we should all coordinate and hopefully we can resolve this soon for you.
> - Mike
>> Hi,
>> To run a job without swift I need to specify "-l nodes=2:bigmem" in
>> either my qsub command or add it
>> to my run script. How do I tell swift to add ":bigmem" to the node
>> total?
>> Thanks, Sheri
>> Swift-user mailing list
>> Swift-user at ci.uchicago.edu
>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
More information about the Swift-user mailing list
