[Swift-user] Adding :bigmem to node count
Michael Wilde
wilde at mcs.anl.gov
Sat Mar 12 10:52:19 CST 2011
Sheri, I am not yet sure, but I think we'll need to add a feature in Swift to enable this specification to be passed down to qsub. That should be doable fairly soon; I had to do something similar to run on Cray XE/XT systems, which I did based on Swift 0.92.
What machine is this for, and which Swift release or build are you running?
In the meantime, a solution you could use more immediately would be to run with manual/persistent coasters, where you could specify your own qsub. This works right now but requires some wrapper scripting that is not yet packaged or sufficiently documented, so thats a route that also requires some work from you and/or us.
I know Justin is working with you, so we should all coordinate and hopefully we can resolve this soon for you.
- Mike
----- Original Message -----
> Hi,
> To run a job without swift I need to specify "-l nodes=2:bigmem" in
> either my qsub command or add it
> to my run script. How do I tell swift to add ":bigmem" to the node
> total?
> Thanks, Sheri
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
Michael Wilde
Computation Institute, University of Chicago
Mathematics and Computer Science Division
Argonne National Laboratory
More information about the Swift-user
