[Swift-user] Argument list to long
Justin M Wozniak wozniak at mcs.anl.gov
Sun Oct 10 18:38:54 CDT 2010
I put that in there in an attempt to connect the Task id with the command
line.  It's just a logging message, right?
On Sun, 10 Oct 2010, Jonathan Monette wrote:
> GridExec TASK_DEFINITION: Task(type=JOB_SUBMISSION,
> identity=urn:0-2-1-1513-3-1-1286751458281) is /bin/bash shared/_swiftwrap
> mProject-23r0czzj\
> -p 2
> What does this line mean? I cannot find the portion of code in _swiftwrap
> that process this.
> On 10/10/10 5:12 PM, Mihael Hategan wrote:
>> I'm good. Try now.
>> On Sun, 2010-10-10 at 17:09 -0500, Jonathan Monette wrote:
>>> Ok.  If you need anymore of my log files I can gather some up for you.
>>> On 10/10/10 5:05 PM, Mihael Hategan wrote:
>>>> Ok. I can reproduce this.
>>>> It means it wasn't the previous problem.
>>>> On Sun, 2010-10-10 at 15:51 -0500, Jonathan Monette wrote:
>>>>> cog is at revision 2910 and swift is at revision 3676.  I have added
>>>>> "wrapper.parameter.mode=files" into my swift.properties.  Here is the
>>>>> output to the screen:
>>>>> RunID: 20101010-1548-ky63yf59
>>>>> Progress:
>>>>> Progress:Progress:Progress:  uninitialized:4
>>>>>      uninitialized:3  uninitialized:4
>>>>> Progress:  Selecting site:4118  Initializing site shared directory:1
>>>>> Progress:  Selecting site:4017  Stage in:101  Submitting:1
>>>>> original callback URI is http://169.254.95.119:37936
>>>>> callback URI has been overridden to http://192.5.86.6:37936
>>>>> Progress:  Selecting site:4017  Submitted:101  Active:1
>>>>> Failed to transfer wrapper log from
>>>>> unrectified-20101010-1548-ky63yf59/info/k on pads
>>>>> unrectified-20101010-1548-ky63yf59/info/7 on pads
>>>>> unrectified-20101010-1548-ky63yf59/info/6 on pads
>>>>> Execution failed:
>>>>> unrectified-20101010-1548-ky63yf59/info/g on pads
>>>>> unrectified-20101010-1548-ky63yf59/info/j on pads
>>>>> unrectified-20101010-1548-ky63yf59/info/t on pads
>>>>> Exception in mProject:
>>>>> Arguments: [-X, raw_dir/2mass-atlas-000218s-j0150091.fits,
>>>>> proj_dir/proj_2mass-atlas-000218s-j0150091.fits, header.hdr]
>>>>> Host: pads
>>>>> Directory: unrectified-20101010-1548-ky63yf59/jobs/6/mProject-6g4u6zzj
>>>>> stderr.txt:
>>>>> stdout.txt:
>>>>> Caused by:
>>>>>        Job failed with an exit code of 254
>>>>> Cleaning up...
>>>>> After that coasters just cancels the other jobs.
>>>>> On 10/10/10 3:26 PM, Mihael Hategan wrote:
>>>>>> Can you re-try the current thing with parameter.mode=files and the
>>>>>> latest trunk first?
>>>>>> On Sun, 2010-10-10 at 15:09 -0500, Jonathan Monette wrote:
>>>>>>> Also, how do I declare the image list as an external type?
>>>>>>> On 10/9/10 3:02 PM, Mihael Hategan wrote:
>>>>>>>> On Sat, 2010-10-09 at 20:00 +0000, jon.monette at gmail.com wrote:
>>>>>>>>> What do you mean by manage them independently?
>>>>>>>> I'm not sure. I guess it's whether swift can skip staging them in and
>>>>>>>> stop keeping track of them. But that's pretty much the same as saying
>>>>>>>> they are "external", so it seems circular.
Justin M Wozniak
More information about the Swift-user mailing list
