[Swift-user] Argument list to long
Jonathan Monette
jon.monette at gmail.com
Sun Oct 10 18:42:42 CDT 2010
correct. I am getting an error coming from my app. The arguments
that are "supposedly" passed to the app are correct but still get an
error. I wanted to see what the command line to my app actually looks
like. It should be mProject -X "in image" "out image" "header file" but
I can't find if Swift is actually calling it like this.
On 10/10/10 6:38 PM, Justin M Wozniak wrote:
> I put that in there in an attempt to connect the Task id with the
> command line. It's just a logging message, right?
> On Sun, 10 Oct 2010, Jonathan Monette wrote:
>> GridExec TASK_DEFINITION: Task(type=JOB_SUBMISSION,
>> identity=urn:0-2-1-1513-3-1-1286751458281) is /bin/bash
>> shared/_swiftwrap mProject-23r0czzj\
>> -p 2
>> What does this line mean? I cannot find the portion of code in
>> _swiftwrap that process this.
>> On 10/10/10 5:12 PM, Mihael Hategan wrote:
>>> I'm good. Try now.
>>> On Sun, 2010-10-10 at 17:09 -0500, Jonathan Monette wrote:
>>>> Ok. If you need anymore of my log files I can gather some up for you.
>>>> On 10/10/10 5:05 PM, Mihael Hategan wrote:
>>>>> Ok. I can reproduce this.
>>>>> It means it wasn't the previous problem.
>>>>> On Sun, 2010-10-10 at 15:51 -0500, Jonathan Monette wrote:
>>>>>> cog is at revision 2910 and swift is at revision 3676. I have added
>>>>>> "wrapper.parameter.mode=files" into my swift.properties. Here is
>>>>>> the
>>>>>> output to the screen:
>>>>>> RunID: 20101010-1548-ky63yf59
>>>>>> Progress:
>>>>>> Progress:Progress:Progress: uninitialized:4
>>>>>> uninitialized:3 uninitialized:4
>>>>>> Progress: Selecting site:4118 Initializing site shared directory:1
>>>>>> Progress: Selecting site:4017 Stage in:101 Submitting:1
>>>>>> original callback URI is http://169.254.95.119:37936
>>>>>> callback URI has been overridden to http://192.5.86.6:37936
>>>>>> Progress: Selecting site:4017 Submitted:101 Active:1
>>>>>> Failed to transfer wrapper log from
>>>>>> unrectified-20101010-1548-ky63yf59/info/k on pads
>>>>>> unrectified-20101010-1548-ky63yf59/info/7 on pads
>>>>>> unrectified-20101010-1548-ky63yf59/info/6 on pads
>>>>>> Execution failed:
>>>>>> unrectified-20101010-1548-ky63yf59/info/g on pads
>>>>>> unrectified-20101010-1548-ky63yf59/info/j on pads
>>>>>> unrectified-20101010-1548-ky63yf59/info/t on pads
>>>>>> Exception in mProject:
>>>>>> Arguments: [-X, raw_dir/2mass-atlas-000218s-j0150091.fits,
>>>>>> proj_dir/proj_2mass-atlas-000218s-j0150091.fits, header.hdr]
>>>>>> Host: pads
>>>>>> Directory:
>>>>>> unrectified-20101010-1548-ky63yf59/jobs/6/mProject-6g4u6zzj
>>>>>> stderr.txt:
>>>>>> stdout.txt:
>>>>>> Caused by:
>>>>>> Job failed with an exit code of 254
>>>>>> Cleaning up...
>>>>>> After that coasters just cancels the other jobs.
>>>>>> On 10/10/10 3:26 PM, Mihael Hategan wrote:
>>>>>>> Can you re-try the current thing with parameter.mode=files and the
>>>>>>> latest trunk first?
>>>>>>> On Sun, 2010-10-10 at 15:09 -0500, Jonathan Monette wrote:
>>>>>>>> Also, how do I declare the image list as an external type?
>>>>>>>> On 10/9/10 3:02 PM, Mihael Hategan wrote:
>>>>>>>>> On Sat, 2010-10-09 at 20:00 +0000, jon.monette at gmail.com wrote:
>>>>>>>>>> What do you mean by manage them independently?
>>>>>>>>> I'm not sure. I guess it's whether swift can skip staging them
>>>>>>>>> in and
>>>>>>>>> stop keeping track of them. But that's pretty much the same as
>>>>>>>>> saying
>>>>>>>>> they are "external", so it seems circular.
Jon
Computers are incredibly fast, accurate, and stupid. Human beings are incredibly slow, inaccurate, and brilliant. Together they are powerful beyond imagination.
- Albert Einstein
More information about the Swift-user
