[Swift-user] Argument list to long
Jonathan Monette jon.monette at gmail.com
Sun Oct 10 18:20:38 CDT 2010
  GridExec TASK_DEFINITION: Task(type=JOB_SUBMISSION,
identity=urn:0-2-1-1513-3-1-1286751458281) is /bin/bash
shared/_swiftwrap mProject-23r0czzj\
  -p 2
What does this line mean? I cannot find the portion of code in
_swiftwrap that process this.
On 10/10/10 5:12 PM, Mihael Hategan wrote:
> I'm good. Try now.
> On Sun, 2010-10-10 at 17:09 -0500, Jonathan Monette wrote:
>> Ok.  If you need anymore of my log files I can gather some up for you.
>> On 10/10/10 5:05 PM, Mihael Hategan wrote:
>>> Ok. I can reproduce this.
>>> It means it wasn't the previous problem.
>>> On Sun, 2010-10-10 at 15:51 -0500, Jonathan Monette wrote:
>>>> cog is at revision 2910 and swift is at revision 3676.  I have added
>>>> "wrapper.parameter.mode=files" into my swift.properties.  Here is the
>>>> output to the screen:
>>>> RunID: 20101010-1548-ky63yf59
>>>> Progress:
>>>> Progress:Progress:Progress:  uninitialized:4
>>>>      uninitialized:3  uninitialized:4
>>>> Progress:  Selecting site:4118  Initializing site shared directory:1
>>>> Progress:  Selecting site:4017  Stage in:101  Submitting:1
>>>> original callback URI is http://169.254.95.119:37936
>>>> callback URI has been overridden to http://192.5.86.6:37936
>>>> Progress:  Selecting site:4017  Submitted:101  Active:1
>>>> Failed to transfer wrapper log from
>>>> unrectified-20101010-1548-ky63yf59/info/k on pads
>>>> unrectified-20101010-1548-ky63yf59/info/7 on pads
>>>> unrectified-20101010-1548-ky63yf59/info/6 on pads
>>>> Execution failed:
>>>> unrectified-20101010-1548-ky63yf59/info/g on pads
>>>> unrectified-20101010-1548-ky63yf59/info/j on pads
>>>> unrectified-20101010-1548-ky63yf59/info/t on pads
>>>> Exception in mProject:
>>>> Arguments: [-X, raw_dir/2mass-atlas-000218s-j0150091.fits,
>>>> proj_dir/proj_2mass-atlas-000218s-j0150091.fits, header.hdr]
>>>> Host: pads
>>>> Directory: unrectified-20101010-1548-ky63yf59/jobs/6/mProject-6g4u6zzj
>>>> stderr.txt:
>>>> stdout.txt:
>>>> Caused by:
>>>>        Job failed with an exit code of 254
>>>> Cleaning up...
>>>> After that coasters just cancels the other jobs.
>>>> On 10/10/10 3:26 PM, Mihael Hategan wrote:
>>>>> Can you re-try the current thing with parameter.mode=files and the
>>>>> latest trunk first?
>>>>> On Sun, 2010-10-10 at 15:09 -0500, Jonathan Monette wrote:
>>>>>> Also, how do I declare the image list as an external type?
>>>>>> On 10/9/10 3:02 PM, Mihael Hategan wrote:
>>>>>>> On Sat, 2010-10-09 at 20:00 +0000, jon.monette at gmail.com wrote:
>>>>>>>> What do you mean by manage them independently?
>>>>>>> I'm not sure. I guess it's whether swift can skip staging them in and
>>>>>>> stop keeping track of them. But that's pretty much the same as saying
>>>>>>> they are "external", so it seems circular.
Jon
Computers are incredibly fast, accurate, and stupid. Human beings are incredibly slow, inaccurate, and brilliant. Together they are powerful beyond imagination.
- Albert Einstein
More information about the Swift-user mailing list
