[Swift-user] Argument list to long
Mihael Hategan
hategan at mcs.anl.gov
Mon Oct 4 20:25:55 CDT 2010
Groovy. Then set "wrapper.parameter.mode=files" in swift.properties.
On Mon, 2010-10-04 at 18:59 -0500, Jonathan Monette wrote:
> well if I am understanding the problem the input list will be about
> 4100 files and the output list will be a single file (unless Swift adds
> more input and output files). I do not think I am using provider
> staging though. In my swift.properties i do not set the
> use.provider.staging option and in etc/swift.properties
> use.provider.staging is set to false.
> On 10/4/10 6:46 PM, Mihael Hategan wrote:
> > On Mon, 2010-10-04 at 18:39 -0500, Jonathan Monette wrote:
> >> Yes. I have to make sure that all 4100 files are created before the
> >> failing app can execute.
> >> The writeData() way seems like a hack to get around the problem is Swift
> >> but I will try it out and see if my script completes.
> >> Mihael: pasted below is the stack trace that was generated in the log file.
> > Yeah. It's what Mike says.
> > But it's not the app arguments. Instead, I'm guessing it's the
> > input/output file lists.
> > There was a scheme in non-provider-staging swift to pass these things in
> > lists, but I'm guessing you are using provider staging. Perhaps some
> > mode to automatically do this for large numbers of arguments is in
> > order.
> > Mihael
More information about the Swift-user
