[Swift-user] Argument list to long
Jonathan Monette
jon.monette at gmail.com
Mon Oct 4 18:59:35 CDT 2010
well if I am understanding the problem the input list will be about
4100 files and the output list will be a single file (unless Swift adds
more input and output files). I do not think I am using provider
staging though. In my swift.properties i do not set the
use.provider.staging option and in etc/swift.properties
use.provider.staging is set to false.
On 10/4/10 6:46 PM, Mihael Hategan wrote:
> On Mon, 2010-10-04 at 18:39 -0500, Jonathan Monette wrote:
>> Yes. I have to make sure that all 4100 files are created before the
>> failing app can execute.
>> The writeData() way seems like a hack to get around the problem is Swift
>> but I will try it out and see if my script completes.
>> Mihael: pasted below is the stack trace that was generated in the log file.
> Yeah. It's what Mike says.
> But it's not the app arguments. Instead, I'm guessing it's the
> input/output file lists.
> There was a scheme in non-provider-staging swift to pass these things in
> lists, but I'm guessing you are using provider staging. Perhaps some
> mode to automatically do this for large numbers of arguments is in
> order.
> Mihael
Jon
Computers are incredibly fast, accurate, and stupid. Human beings are incredibly slow, inaccurate, and brilliant. Together they are powerful beyond imagination.
- Albert Einstein
More information about the Swift-user
