[Swift-user] Argument list to long
    Jonathan Monette
    jon.monette at gmail.com
    Mon Oct  4 21:39:18 CDT 2010
  By setting "wrapper.parameter.mode=files" I get "failed to transfer
wrapper logs".  Here is my swift.properties file.
execution.retries=0
sitedir.keep=true
status.mode=provider
//wrapper.log.always.transfer=true
foreach.maxthreads=1024
I have tried this with "wrapper.log.always.transfer=true" both commented
and uncommented still get the same error.
On 10/04/2010 08:25 PM, Mihael Hategan wrote:
> Groovy. Then set "wrapper.parameter.mode=files" in swift.properties.
> On Mon, 2010-10-04 at 18:59 -0500, Jonathan Monette wrote:
>> well if I am understanding the problem the input list will be about
>> 4100 files and the output list will be a single file (unless Swift adds
>> more input and output files).  I do not think I am using provider
>> staging though.  In my swift.properties i do not set the
>> use.provider.staging option and in etc/swift.properties
>> use.provider.staging is set to false.
>> On 10/4/10 6:46 PM, Mihael Hategan wrote:
>>> On Mon, 2010-10-04 at 18:39 -0500, Jonathan Monette wrote:
>>>> Yes.  I have to make sure that all 4100 files are created before the
>>>> failing app can execute.
>>>> The writeData() way seems like a hack to get around the problem is Swift
>>>> but I will try it out and see if my script completes.
>>>> Mihael: pasted below is the stack trace that was generated in the log file.
>>> Yeah. It's what Mike says.
>>> But it's not the app arguments. Instead, I'm guessing it's the
>>> input/output file lists.
>>> There was a scheme in non-provider-staging swift to pass these things in
>>> lists, but I'm guessing you are using provider staging. Perhaps some
>>> mode to automatically do this for large numbers of arguments is in
>>> order.
>>> Mihael
Jon
Computers are incredibly fast, accurate, and stupid. Human beings are incredibly slow, inaccurate, and brilliant. Together they are powerful beyond imagination.
- Albert Einstein
More information about the Swift-user
