[Swift-user] swift returns error on pads
Allan Espinosa
aespinosa at cs.uchicago.edu
Sun Feb 28 00:38:05 CST 2010
I think it should be workersPerNode
On Sun, Feb 28, 2010 at 12:08:12AM -0600, Zhao Zhang wrote:
> Hi,
> I have a following error message from swift when I ran it on pads
> with coaster. The swift
> I am running is at
> [zzhang at login2 final]$ which swift
> /home/wilde/bigdata/swift/bin/swift
> I am confused about the configuration settings in the sites.xml
> file. Could anybody point the
> error in the settings? thanks.
> Best
> zhao
> PS: I am pasting my pbs.xml and stdout from swift here.
> [zzhang at login2 final]$ cat pbs.xml
> <config>
> <pool handle="pbs">
> <profile namespace="globus" key="maxwalltime">00:00:10</profile>
> <profile namespace="globus" key="maxtime">1800</profile>
> <execution provider="coaster" url="none" jobManager="local:pbs"/>
> <profile namespace="globus" key="coastersPerNode">8</profile>
> <profile namespace="karajan" key="initialScore">10000</profile>
> <profile namespace="karajan" key="jobThrottle">.63</profile>
> <gridftp url="local://localhost" />
> <workdirectory >/home/zzhang/swiftwork</workdirectory>
> </pool>
> [zzhang at login2 final]$ time swift -tc.file ./tc sites.file ./pbs.xml
> movie.swift
> Swift svn swift-r3255 (swift modified locally) cog-r2723
> RunID: 20100228-0003-xeza2uh4
> Progress:
> Progress:Progress: uninitialized:3 uninitialized:3
> Progress: Selecting site:936 Stage in:54 Submitting:1 Submitted:9
> Progress: Selecting site:936 Stage in:21 Submitted:43
> Worker task failed: Error submitting block task
> org.globus.cog.abstraction.impl.common.task.TaskSubmissionException:
> Cannot submit job: Could not submit job (qsub reported an exit code
> of 188).
> qsub: Job exceeds queue resource limits MSG=cannot locate feasible nodes
> at org.globus.cog.abstraction.impl.scheduler.common.AbstractJobSubmissionTaskHandler.submit(AbstractJobSubmissionTaskHandler.java:63)
> at org.globus.cog.abstraction.impl.common.AbstractTaskHandler.submit(AbstractTaskHandler.java:46)
> at org.globus.cog.abstraction.impl.common.task.ExecutionTaskHandler.submit(ExecutionTaskHandler.java:43)
> at org.globus.cog.abstraction.coaster.service.job.manager.BlockTaskSubmitter.run(BlockTaskSubmitter.java:66)
> Caused by:
> org.globus.cog.abstraction.impl.scheduler.common.ProcessException:
> Could not submit job (qsub reported an exit code of 188).
> at org.globus.cog.abstraction.impl.scheduler.common.AbstractExecutor.start(AbstractExecutor.java:100)
> at org.globus.cog.abstraction.impl.scheduler.common.AbstractJobSubmissionTaskHandler.submit(AbstractJobSubmissionTaskHandler.java:53)
> ... 3 more
> Progress: Selecting site:936 Submitted:63 Active:1
> Failed to transfer wrapper log from
> movie-20100228-0003-xeza2uh4/info/v on pbs
> Execution failed:
> Exception in transform:
> Arguments: [training_set_1000/mv_0001283.txt]
> Host: pbs
> Directory: movie-20100228-0003-xeza2uh4/jobs/v/transform-vt0goeoj
> stderr.txt:
> stdout.txt:
> Caused by:
> Task failed: Error submitting block task
> of 188).
> Caused by:
> ... 3 more
> Cleaning up...
> Shutting down service at https://192.5.86.6:50002
> Got channel MetaChannel: 2090567670 -> null
> +Canceling job 5536.svc.pads.ci.uchicago.edu
> Canceling job 5537.svc.pads.ci.uchicago.edu
> Canceling job 5538.svc.pads.ci.uchicago.edu
> Failed to shut down block
> Can only cancel an active task
> at org.globus.cog.abstraction.impl.scheduler.common.AbstractExecutor.cancel(AbstractExecutor.java:177)
> at org.globus.cog.abstraction.impl.scheduler.common.AbstractJobSubmissionTaskHandler.cancel(AbstractJobSubmissionTaskHandler.java:85)
> at org.globus.cog.abstraction.impl.common.AbstractTaskHandler.cancel(AbstractTaskHandler.java:70)
> at org.globus.cog.abstraction.impl.common.task.ExecutionTaskHandler.cancel(ExecutionTaskHandler.java:96)
> at org.globus.cog.abstraction.impl.common.task.ExecutionTaskHandler.cancel(ExecutionTaskHandler.java:85)
> at org.globus.cog.abstraction.coaster.service.job.manager.BlockTaskSubmitter.cancel(BlockTaskSubmitter.java:44)
> at org.globus.cog.abstraction.coaster.service.job.manager.Block.forceShutdown(Block.java:271)
> at org.globus.cog.abstraction.coaster.service.job.manager.Block.shutdown(Block.java:252)
> at org.globus.cog.abstraction.coaster.service.job.manager.BlockQueueProcessor.shutdownBlocks(BlockQueueProcessor.java:487)
> at org.globus.cog.abstraction.coaster.service.job.manager.BlockQueueProcessor.shutdown(BlockQueueProcessor.java:477)
> at org.globus.cog.abstraction.coaster.service.job.manager.JobQueue.shutdown(JobQueue.java:70)
> at org.globus.cog.abstraction.coaster.service.CoasterService.shutdown(CoasterService.java:211)
> at org.globus.cog.abstraction.coaster.service.ServiceShutdownHandler.requestComplete(ServiceShutdownHandler.java:28)
> at org.globus.cog.karajan.workflow.service.handlers.RequestHandler.receiveCompleted(RequestHandler.java:84)
> at org.globus.cog.karajan.workflow.service.channels.AbstractKarajanChannel.handleRequest(AbstractKarajanChannel.java:348)
> at org.globus.cog.karajan.workflow.service.channels.AbstractPipedChannel.sendTaggedData(AbstractPipedChannel.java:58)
> at org.globus.cog.karajan.workflow.service.channels.AbstractKarajanChannel.sendTaggedData(AbstractKarajanChannel.java:126)
> at org.globus.cog.karajan.workflow.service.commands.Command.send(Command.java:121)
> at org.globus.cog.karajan.workflow.service.commands.Command.send(Command.java:171)
> at org.globus.cog.karajan.workflow.service.commands.Command.executeAsync(Command.java:162)
> at org.globus.cog.abstraction.impl.execution.coaster.ServiceManager$ServiceReaper.run(ServiceManager.java:425)
More information about the Swift-user
