[Swift-user] Re: Copy of parallel scripting paper
William Emmanuel S. Yu
william.yu at novare.com.hk
Mon Nov 16 02:48:44 CST 2009
Hey. Thanks for the quick response. I do have to note that I haven't
gone through much of the documentation yet. But, these tidbits
definitely help.
Again thanks.
On Mon, 2009-11-16 at 02:35 -0600, Allan Espinosa wrote:
> Hi william,
> Yeah. typically i place a tc.data in my current directory and then
> specify it with the "-tc.file ./tc.data" option.
> I guess we can run on PBS Torque. Here's a sample sites.xml config:
> <config>
> <pool handle="TERAPORT" sysinfo="INTEL32::LINUX">
> <execution provider="pbs" url="none" />
> <gridftp url="local://localhost" />
> <workdirectory >/home/aespinosa</workdirectory>
> <profile namespace="karajan" key="initialScore">2.02</profile>
> <profile namespace="karajan" key="jobThrottle">1.98</profile>
> <profile namespace="globus" key="queue">fast</profile>
> <profile namespace="globus" key="maxwalltime">01:00:00</profile>
> </pool>
> </config>
> My initialScore and jobThrottle score enables me to submit a maximum
> of 200 jobs at a time.
> Btw, I'm cc'ing you to the swift-user mailing list. Hope you enjoy
> tinkering around Swift!
> -Allan
> 2009/11/16 William Emmanuel S. Yu <william.yu at novare.com.hk>:
> > I found the tc.data file. geez... its in a strange place! The etc folder
> > in the distribution directory.
> > On Mon, 2009-11-16 at 16:22 +0800, William Emmanuel Yu wrote:
> >> On Mon, 2009-11-16 at 02:14 -0600, Allan Espinosa wrote:
> >> > I guess that works. But if you have a scheduler, you should use it.
> >> > we have support for pbs, cobalt and condor. any unsupported scheduler
> >> > can be interfaced with Globus GRAM2 or GRAM4. From my perspective,
> >> > the cluster sysads should make it easy for its users to submit jobs :)
> >> Ok right now. That systems uses Torque and is really maintained at this
> >> point. So it was a real challenge using it. But, I managed to write a
> >> script with bash and mpirun that got the job done. However, I did
> >> encounter a lot of dependency issues. Haha. As expected.
> >> Do you have a document on torque integration? At least a quick one.
> >> Btw, I am using the default swift binary on my laptop with no installed
> >> scheduler. I ran into the following error:
> >> "Could not find any valid host for task "Task(type=UNKNOWN,
> >> identity=urn:cog-1258359742934)" with constraints {tr=convert,
> >> filenames=[Ljava.lang.String;@2de41d, trfqn=convert,
> >> filecache=org.griphyn.vdl.karajan.lib.cache.CacheMapAdapter at db4bcf}"
> >> Which is strange as I am not using any scheduler.
> >> Thanks!
> >> > 2009/11/15 William Emmanuel Yu <wyu at ateneo.edu>:
> >> > > After reading the article, I think I have a better appreciate of the
> >> > > problems you are trying to solve. Let me try to read about SWIFT more.
> >> > > What is the easier way to run SWIFT on a small cluster (say 64 cores on
> >> > > 16 nodes)? Can I just do an NFS and passwordless-SSH thing? I think I
> >> > > will try to help a buddy of mine with his thesis on aquatic migrations
> >> > > in UP as practice.
> >> > > Thanks.
> >> > > On Thu, 2009-11-12 at 20:11 -0600, Allan Espinosa wrote:
> >> > >> you can try the swift tutorial designed for localhost:
> >> > >> http://www.ci.uchicago.edu/swift/guides/tutorial.php
> >> > >> 2009/11/12 William Emmanuel Yu <wyu at ateneo.edu>:
> >> > >> > let me review first if this is easier to teach ... but, if you have a
> >> > >> > cookbook for a quick local install then that would also be cool.
> >> > >> > On Thu, 2009-11-12 at 19:08 -0600, Allan Espinosa wrote:
> >> > >> >> its user and setup easy when you use a local scheduler (run from
> >> > >> >> localhost). I can help you on the setup on local host or via ssh.
> >> > >> >> Some of my colleagues have also tried using this over Amazon EC2.
> >> > >> >> -Allan
> >> > >> >> > interesting.. but this is setup heavy but user easy right?
> >> > >> >> > On Thu, 2009-11-12 at 18:58 -0600, Allan Espinosa wrote:
> >> > >> >> >> hi william
> >> > >> >> >> see attached file.
> >> > >> >> >> We are using Swift (http://www.ci.uchicago.edu/swift). It has
> >> > >> >> >> adapters to cluster schedulers like PBS, GRAM2, GRAM4, Cobalt and
> >> > >> >> >> Condor. But you can use ssh and local (fork) for a start.
> >> > >> >> >> We couple it to Falkon (http://dev.globus.org/wiki/Incubator/Falkon)
> >> > >> >> >> for faster job throughput in short-time jobs and deployments on
> >> > >> >> >> supercomputers.
> >> > >> >> >> -Allan
> >> > >> >> >> > Can I get a copy of this paper? What tools are you using now?
> >> > >> >> >> > William Emmanuel S. Yu (杨怀义)
> >> > >> >> >> > Department of Information Systems and Computer Science
> >> > >> >> >> > Ateneo de Manila University
> >> > >> >> >> > email : wyu at ateneo dot edu
> >> > >> >> >> > blog : http://hip2b2.yutivo.org/
> >> > >> >> >> > web : http://CNG.ateneo.edu/cng/wyu/
> >> > >> >> >> > phone : +63(2)4266001 loc. 4186
> >> > >> >> >> > GPG : http://CNG.ateneo.net/cng/wyu/wyy.pgp
> >> > >> >> >> > Confidentiality Issue: This message is intended only for the use of the
> >> > >> >> >> > addressee and may contain information that is privileged and
> >> > >> >> >> > confidential. If you are not the intended recipient, you are hereby
> >> > >> >> >> > notified that any use or dissemination of this communication is strictly
> >> > >> >> >> > prohibited. If you have received this communication in error, please
> >> > >> >> >> > notify us immediately by reply and delete this message from your system.
> > Novare Technologies Inc.
> > 6th Floor Peninsula Court Building,
> > Makati Avenue corner Paseo de Roxas Avenue,
> > Makati City, 1226 Philippines
> > email : william dot yu at novare dot com dot hk
> > web : www.novare.com.hk
More information about the Swift-user
