[Swift-user] RAxML error msgs
Fangfang Xia
fangfang at uchicago.edu
Thu Nov 12 18:12:00 CST 2009
I am trying to run RAxML with Swift on Surveyor and am getting the
following error mesages. Could you help me with this? Thanks.
directory:
~fangfang/work/jgi/phylo/test.raxml/
command line:
swift -tc.file tc.data -sites.file sites.xml raxmlex1.swift
Failed to transfer wrapper log from
raxmlex1-20091112-1726-ct8vv8tf/info/m on surveyor
Progress: Submitted:7
Failed to connect: Connection timed out at
/home/fangfang/.globus/coasters/cscript7914625247065953287.pl line
129.
129.
129.
Progress: Submitted:6 Active:1
raxmlex1-20091112-1726-ct8vv8tf/info/p on surveyor
Worker task failed: 1112-260539-000002Block task ended prematurely
Statement unlikely to be reached at
592.
(Maybe you meant system() when you said exec()?)
592.
592.
592.
More information about the Swift-user
