[Swift-user] Teraport question
Mihael Hategan hategan at mcs.anl.gov
Thu Mar 19 18:22:12 CDT 2009
On Thu, 2009-03-19 at 18:13 -0500, Michael Wilde wrote:
> On 3/19/09 4:54 PM, Mihael Hategan wrote:
> > I guess the explanation above in the user guide is a little unclear. The
> > main use for coasterWorkerMaxwalltime is to put a cap on the walltime
> > for the workers, which may otherwise get a walltime that would cause the
> > queuing system to bark.
> So is the following summary correct (as far as it goes)?
> "If coasterWorkerMaxwalltime is specified for a site (which must be
> using coasters) then it determines the wall time that will be requested
> from the local scheduler when the coaster worker job is submitted. This
> will override all other time specifications for the worker job, and is
> typically the easiest way to manage the time requests for these jobs.
The worker job walltime is otherwise unspecified (i.e. the software
governing the workers can choose anything it pleases).
> "If coasterWorkerMaxwalltime is *not* specified then the maxWallTime
> computed for the worker is based on ???
Nothing. It shall remain undisclosed (current implementation says
walltime_of_job_that_started_the_worker * 10 + 1 minute)
> - app jobs queued, and their tc.data maxwalltime specs?
> - site maxwalltime? multiplied by some scale factor?
> "If no times are specified, but a queue is specified for the site, then
> the wall time allowed the worker job is determined by the local
> scheduler, based on the requested queue."
I have no idea where that came from.
More information about the Swift-user mailing list
