[Swift-user] Teraport question
    Mihael Hategan
    hategan at mcs.anl.gov
    Thu Mar 19 16:54:07 CDT 2009
On Thu, 2009-03-19 at 16:42 -0500, Michael Wilde wrote:
> I may have asked too soon, as I just found this in the user guide:
> "coasterWorkerMaxwalltime specifies the maxwalltime to be used when
> submitting coaster workers. This profile entry is used by the coaster
> execution provider. If this entry is not specified, the coaster provider
> will compute a maxwalltime based on the maxwalltime of jobs submitted.
> (since Swift 0.9) "
> Which seems to leave a lot of room for interpretation, but is the
> following reasonable?
> If you can, just specify coasterWorkerMaxwalltime, and that will go to
> the resource manager scheduler in the absence of any other times.
> But, if you are running jobs on many sites, some of which specify
> coasters and some of which dont, then I take the above to mean that
> coasters will compute a max walltime base on whatever jobs it sees for a
> given site at the moment???? And how does it treat maxWalltime for an
> app (from tc.data) vs. a site?
> Can you provide some simple guidelines to make this whole issue of
> queues and times easy to understand and specify?
I guess the explanation above in the user guide is a little unclear. The
main use for coasterWorkerMaxwalltime is to put a cap on the walltime
for the workers, which may otherwise get a walltime that would cause the
queuing system to bark.
More information about the Swift-user
