[Swift-user] Teraport question
Michael Wilde
wilde at mcs.anl.gov
Thu Mar 19 16:34:56 CDT 2009
The TeraPort queue policies are described at:
http://www.ci.uchicago.edu/wiki/bin/view/Teraport/QueuePolicies
which says the fast queue gives you up to an hour.
Separate from that, further clarification of queue and time specs would
be helpful.
There was much discussion on the devel list about how times are treated
in coaster scheduling. This left me confused as to whether time specs
for coaster jobs were working as desired or still in flux. Specifically:
1 - it is unclear if profile time specs are all in hh:mm:ss. I think I
reported to swift-devel a coaster case where they were not interpreted
in that standard manner.
2 - it was unclear whether the time is for the pbs (i.e.,
coaster-worker) job or for the swift apps that run on them. Ie how does
"coasterWorkerMaxwalltime" which is mentioned in the user guide interact
with maxwalltime in the globus profile?
3 - is maxwalltime treated the same or different if specified in tc.data
vs sites.xml, with respect to coasters?
4 - if I specify only a queue but no time limit, do I get the max for
that queue? (would hope so...)
5 - is job time handling now working as the developers currently intend
or are there outstanding issues in this area?
On 3/19/09 4:07 PM, Ben Clifford wrote:
> You can run the qstat command to see if your jobs are being queued, what
> state they are in, and which queue they went to. For example:
> 878629.tp-mgt null yuechen 0 Q
> extended
> shows a job submitted by you, that is in state Q (meaning queued) and that
> it is in the extended queue.
> There are a lot of other jobs running on teraport at the moment. You might
> have more luck using a different queue, such as 'fast' which you can
> specify by adding a line something like this:
> <profile namespace="globus" key="queue">fast</profile>
> to your site definition.
> However, you'll likely still have to wait some time for your jobs to run -
> that is the nature of using a job queue...
More information about the Swift-user
