[Swift-user] Teraport question
Ben Clifford benc at hawaga.org.uk
Thu Mar 19 16:07:58 CDT 2009
You can run the qstat command to see if your jobs are being queued, what
state they are in, and which queue they went to. For example:
878629.tp-mgt             null             yuechen                0 Q
extended
shows a job submitted by you, that is in state Q (meaning queued) and that
it is in the extended queue.
There are a lot of other jobs running on teraport at the moment. You might
have more luck using a different queue, such as 'fast' which you can
specify by adding a line something like this:
<profile namespace="globus" key="queue">fast</profile>
to your site definition.
However, you'll likely still have to wait some time for your jobs to run -
that is the nature of using a job queue...
More information about the Swift-user mailing list
