[Swift-user] Does SWIFT_JOBDIR_PATH work for output?
Ben Clifford benc at hawaga.org.uk
Mon Mar 16 09:29:22 CDT 2009
On Mon, 16 Mar 2009, Ben Clifford wrote:
> provider; and if you run a falkon worker on the same system as you submit
> from (so it ends up doing local execution through falkon) you should be
> able to run that test successfully too.
Actually if you get that far, you should be able to run the entire test
suite that way, by running ./run in the tests/ directory from SVN.
Then go and drink coffee for an hour or something; but it would give much
greater confidence in the integration of falkon and swift.
More information about the Swift-user mailing list
