[Swift-user] Does SWIFT_JOBDIR_PATH work for output?
    Ben Clifford
    benc at hawaga.org.uk
    Mon Mar 16 09:14:38 CDT 2009
On Mon, 16 Mar 2009, Michael Wilde wrote:
> Its very possible that Falkon is loosing the environment. The local test will
> show if thats likely.
Far be it for me to make such an accusation.
The test suite does test environment passing, in
tests/misc/path-prefix.sh, at least as far as the local provider.
You should be able to run tests/misc/path-prefix.sh against your local
provider; and if you run a falkon worker on the same system as you submit
from (so it ends up doing local execution through falkon) you should be
able to run that test successfully too.
More information about the Swift-user
