[Swift-user] Does SWIFT_JOBDIR_PATH work for output?
Michael Wilde
wilde at mcs.anl.gov
Mon Mar 16 08:59:04 CDT 2009
Its very possible that Falkon is loosing the environment. The local test
will show if thats likely.
On 3/16/09 8:57 AM, Michael Wilde wrote:
> On 3/16/09 8:48 AM, Ben Clifford wrote:
>> On Mon, 16 Mar 2009, Michael Wilde wrote:
>>> Ah, I see: in wrapper.sh the "info" function which logs the env etc
>>> is only
>>> invoked on failure, it seems. Unless you see an error in my
>>> sites.xml below,
>>> I'll add extra logging to wrapper.sh to see what my env is. Or test
>>> with
>>> printenv as the app.
>> Yes, using env/printenv should be easy to do.
>> Are you using an unmodified Swift? Please can you send a log from
>> running something like first.swift, and its corresponding info file.
> The "only" mod I made to this swift (from trunk, rev# in log) is to
> change the arg separator from | to ^ in wrapper.sh and vdl-int.k, to be
> compatible with Falkon.
> Its possible that broke env passing.
> The log and info file for the pe.swift run, which is one job, is in:
> http://www.ci.uchicago.edu/~wilde/pe-20090316-0845-sqceiryc.log
> http://www.ci.uchicago.edu/~wilde/printenv-rx6v318j-info
>> Also, try with that exact same Swift installation, but running on
>> localhost using the local provider and specifying SWIFT_JOBDIR_PATH.
> will do.
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
More information about the Swift-user
