[Swift-user] Does SWIFT_JOBDIR_PATH work for output?
Ben Clifford benc at hawaga.org.uk
Mon Mar 16 06:54:22 CDT 2009
On Mon, 16 Mar 2009, Michael Wilde wrote:
> No, this is an application log file - just one of the app's outputs. I could
> see these ".log" files being created in the workdir as soon as the script
> started, and was able to tail -f these files to see the app's progress.
OK, those should all appear under the SWIFT_JOBDIR_PATH directory.
I've never seen that profile specified in tc.data; only in sites.xml. It
might be that something is wrong there - try it in sites.xml
In the -info log for a job, you always should see one of two log messages:
   "Job directory mode is: local copy"
or
  "Job directory mode is: link on shared filesystem"
with the former meaning that SWIFT_JOBDIR_PATH is being detected in the
wrapper environment, and the latter meaning that it is not.
Looking for those lines in your present setup would be useful.
More information about the Swift-user mailing list
