[Swift-user] Does SWIFT_JOBDIR_PATH work for output?
Michael Wilde
wilde at mcs.anl.gov
Mon Mar 16 07:01:45 CDT 2009
I see:
Job directory mode is: link on shared filesystem
I'll try moving the env var to sites.xml.
In this case, I wanted only this job to get this behavior, as a later
job in the script analyzes all the files that are produced in parallel,
and might eventually exceed the available limited local BG/P filesystem
(ramdisk).
But for the tests Im doing now this is not a problem.
On 3/16/09 6:54 AM, Ben Clifford wrote:
> On Mon, 16 Mar 2009, Michael Wilde wrote:
>> No, this is an application log file - just one of the app's outputs. I could
>> see these ".log" files being created in the workdir as soon as the script
>> started, and was able to tail -f these files to see the app's progress.
> OK, those should all appear under the SWIFT_JOBDIR_PATH directory.
> I've never seen that profile specified in tc.data; only in sites.xml. It
> might be that something is wrong there - try it in sites.xml
> In the -info log for a job, you always should see one of two log messages:
> "Job directory mode is: local copy"
> or
> "Job directory mode is: link on shared filesystem"
> with the former meaning that SWIFT_JOBDIR_PATH is being detected in the
> wrapper environment, and the latter meaning that it is not.
> Looking for those lines in your present setup would be useful.
More information about the Swift-user
