[Swift-user] Does SWIFT_JOBDIR_PATH work for output?
Michael Wilde wilde at mcs.anl.gov
Mon Mar 16 06:50:07 CDT 2009
On 3/16/09 4:07 AM, Ben Clifford wrote:
> On Sun, 15 Mar 2009, Michael Wilde wrote:
>> Does the env var SWIFT_JOBDIR_PATH set the jobdir for each job in a script to
>> this value, and use it for output as well as input?  Or is it only used for
>> input?
> It sets the root under which the per-job working directories exist, that
> is otherwise the run shared directory with /jobs/ on the end
OK, thats exactly what I as hoping it did.
>> But as my jobs run, I can see that they are writing their log data, line by
>> line, to the output directories of the shared workdirectory. Thats the
>> overhead I was hoping to avoid with SWIFT_JOBDIR_PATH.
> You mean the wrapper logs are being written to the wrapper log directory
> info/ ?
No, this is an application log file - just one of the app's outputs. I
could see these ".log" files being created in the workdir as soon as the
script started, and was able to tail -f these files to see the app's
progress.
So if this feature works as above, then something is wrong. Possibly I
didnt specify it correctly, or its broken. I'll need to investigate.
> That will happen. Zhao has hacked things in the past to not store the log.
> Another thing that can be done is to create the log in the job directory
> and copy it at the end. However, in certain failure modes you then won't
> get any log data at all.
> I can implement an option for that.
More information about the Swift-user mailing list
