[Swift-user] Swift on OSG sites
    Allan Espinosa
    aespinosa at cs.uchicago.edu
    Tue Jun 30 12:40:04 CDT 2009
hello erin.
i suggest you write everything in absolute paths or add manually a
PATH env variable in your scripts.
also, do you really need the swift submit program running on the osg
site itself?
-Allan
2009/6/30 Hodgess, Erin <HodgessE at uhd.edu>:
> Hi Swift Users:
> I'm trying to run OOPS via Swift on an OSG site, but it can't find Swift:
> [erin at tp-login2 oop1]$ globus-job-run osgce.cs.clemson.edu
> /home/osg/swoops/users/hockyg/swift/runradial_norefine_teraport.sh plist
> input 4
> /home/osg/swoops/users/hockyg/swift/runradial_norefine_teraport.sh: line 10:
> swift: command not found
> Now when I put the path for Swift in a simple example, I get:
> /home/erin/cog/modules/swift/dist/swift-svn/bin/swift /home/osg/hello.swift
> GRAM Job failed because the executable does not exist (error code 5)
> Has anyone seen this before, please?
> Thanks,
> Erin
> Erin M. Hodgess, PhD
> Associate Professor
> Department of Computer and Mathematical Sciences
> University of Houston - Downtown
> mailto: hodgesse at uhd.edu
Allan M. Espinosa <http://allan.88-mph.net/blog>
PhD student, Computer Science
University of Chicago <http://people.cs.uchicago.edu/~aespinosa>
More information about the Swift-user
