[Swift-user] Swift on OSG sites
    Hodgess, Erin
    HodgessE at uhd.edu
    Tue Jun 30 12:43:30 CDT 2009
We're trying to run OOPS, and the ultimate goal is to run OOPS via Swift.
Our next step is to try some OOPS commands at the OSG sites.
thanks,
Erin
Erin M. Hodgess, PhD
Associate Professor
Department of Computer and Mathematical Sciences
University of Houston - Downtown
mailto: hodgesse at uhd.edu
-----Original Message-----
From: yecartes at gmail.com on behalf of Allan Espinosa
Sent: Tue 6/30/2009 12:40 PM
To: Hodgess, Erin
Cc: swift-user at ci.uchicago.edu
Subject: Re: [Swift-user] Swift on OSG sites
hello erin.
i suggest you write everything in absolute paths or add manually a
PATH env variable in your scripts.
also, do you really need the swift submit program running on the osg
site itself?
-Allan
2009/6/30 Hodgess, Erin <HodgessE at uhd.edu>:
> Hi Swift Users:
> I'm trying to run OOPS via Swift on an OSG site, but it can't find Swift:
> [erin at tp-login2 oop1]$ globus-job-run osgce.cs.clemson.edu
> /home/osg/swoops/users/hockyg/swift/runradial_norefine_teraport.sh plist
> input 4
> /home/osg/swoops/users/hockyg/swift/runradial_norefine_teraport.sh: line 10:
> swift: command not found
> Now when I put the path for Swift in a simple example, I get:
> /home/erin/cog/modules/swift/dist/swift-svn/bin/swift /home/osg/hello.swift
> GRAM Job failed because the executable does not exist (error code 5)
> Has anyone seen this before, please?
> Thanks,
> Erin
> Associate Professor
Allan M. Espinosa <http://allan.88-mph.net/blog>
PhD student, Computer Science
University of Chicago <http://people.cs.uchicago.edu/~aespinosa>
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20090630/b314ddee/attachment.html>
More information about the Swift-user
