[Swift-user] Which OSG directories to use?
Mats Rynge rynge at renci.org
Mon Jun 29 11:41:49 CDT 2009
Michael Wilde wrote:
>> But when you look at the sites.xml file, it has:
>> /export/osg/data/engage/tmp/Clemson-ciTeam
>> as the working directory.
> I suspect that's either the "$DATA" or "$TMP" directory for that site.
Yes, that is $OSG_DATA/$VO_NAME/tmp/
$OSG_DATA is a shared directory across the resource and is the correct
place to put temporary data during a run. Make sure you clean up when
you are done.
Make sure use --vo=[VO] for the VO you are a member of.
Do not use $HOME for anything on OSG.
Mats Rynge
Renaissance Computing Institute <http://www.renci.org>
More information about the Swift-user mailing list
