[Swift-user] Which OSG directories to use?
    Michael Wilde
    wilde at mcs.anl.gov
    Mon Jun 29 11:15:07 CDT 2009
was: Re: first question o'the day
On 6/29/09 10:19 AM, Hodgess, Erin wrote:
> Hi all!
> Here is my first question (of many) for today.
> I have a copy of the sites.xml file, which contains the names of the
> sites and also working directories.
> Please consider the following:
> When I check /bin/pwd on osgce.cs.clemson.edu, I get
> [erin at tp-login2 oops]$ globus-job-run osgce.cs.clemson.edu /bin/pwd
> /home/osg
> So the directory is /home/osg
Thats likely the $HOME directory of the login for your VO (Engage?) on
that site.
> But when you look at the sites.xml file, it has:
> /export/osg/data/engage/tmp/Clemson-ciTeam
> as the working directory.
I suspect that's either the "$DATA" or "$TMP" directory for that site.
These should be described in some OSG document - maybe googling for
these will help. Maybe the ENgage VO has some notes about site usage.
> My question is:  which directory should I use, please?
I suggest using sites.xml as its generated, but report any problems you
find.
- Mike
> Thanks,
> Erin
> Erin M. Hodgess, PhD
> Associate Professor
> Department of Computer and Mathematical Sciences
> University of Houston - Downtown
> mailto: hodgesse at uhd.edu
More information about the Swift-user
