[swift-user] List of OSG sites
    Mihael Hategan
    hategan at mcs.anl.gov
    Fri Jun 26 15:59:02 CDT 2009
Doesn't work.
My .soft:
@default
@globus-4
+java-sun
+torque
+maui
+condor
@osg
+osg-client
[hategan at tp-login2 ~]$ condor_status
Neither the environment variable CONDOR_CONFIG,
/etc/condor/, nor ~condor/ contain a condor_config source.
Either set CONDOR_CONFIG to point to a valid config source,
or put a "condor_config" file in /etc/condor or ~condor/
Exiting.
On Fri, 2009-06-26 at 15:41 -0500, Michael Wilde wrote:
> If you added your swift/bin directory to your path manually, when you
> run resoft you may loose that and need to do it again.
> On 6/26/09 3:33 PM, Hodgess, Erin wrote:
> > This is getting weird:
> > [erin at tp-login2 ~]$  swift-osg-ress-site-catalog --engage-verified
> > -bash: swift-osg-ress-site-catalog: command not found
> > Erin M. Hodgess, PhD
> > Associate Professor
> > Department of Computer and Mathematical Sciences
> > University of Houston - Downtown
> > mailto: hodgesse at uhd.edu
> > -----Original Message-----
> > From: hockyg at gmail.com on behalf of Glen Hocky
> > Sent: Fri 6/26/2009 3:24 PM
> > To: Hodgess, Erin
> > Cc: Michael Wilde; Melinda Chin; Swift User Discussion List
> > Subject: Re: [swift-user] List of OSG sites
> > It's likely this error can be fixed by the same thing Zhao did to get condor
> > working last week (since the command works for me). Try putting @osg and
> > +osg-client into your ~/.soft file and then resetting up by either logging
> > back in or typing "resoft;source ~/.bashrc"
> > for reference, here is my ~/.soft file
> > @python-2.5
> > +java-sun
> > +osg-client
> > +maui
> > +torque
> > +R
> > +matlab-7.7
> > +apache-ant
> > +gx-map
> > @osg
> > @default
> > @globus-4
> > On Fri, Jun 26, 2009 at 3:20 PM, Hodgess, Erin <HodgessE at uhd.edu> wrote:
> >  >  I'm having trouble with the swift-osg-ress-site-catalog command:
> >  > [erin at tp-login2 swift]$  swift-osg-ress-site-catalog --engage-verified
> >  > Exiting.
> >  > <config>
> >  > </config>
> >  > Any help is much appreciated.
> >  > Thanks,
> >  > Erin
> >  > Associate Professor
> >  > From: swift-user-bounces at ci.uchicago.edu on behalf of Michael Wilde
> >  > Sent: Fri 6/26/2009 2:14 PM
> >  > To: Melinda Chin
> >  > Cc: Swift User Discussion List
> >  >  From a practical point of view, you can get the sites in the OSG
> >  > "engagement" VO using this Swift command, which returns the list as a
> >  > sites.xml file:
> >  > That command also has options for getting sites from other VOs
> >  >    swift-osg-ress-site-catalog --vo=osg
> >  > On 6/26/09 2:04 PM, Melinda Chin wrote:
> >  > > Here's what I think is a simple question but can't find the answer to?
> >  > > Where can I find a list of all the osg sites?
> >  > > Thank you,
> >  > > Melinda Chin
> >  > > _______________________________________________
> >  > > Swift-user mailing list
> >  > > Swift-user at ci.uchicago.edu
> >  > > http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
More information about the Swift-user
