[swift-user] List of OSG sites
    Michael Wilde
    wilde at mcs.anl.gov
    Fri Jun 26 15:41:05 CDT 2009
If you added your swift/bin directory to your path manually, when you
run resoft you may loose that and need to do it again.
On 6/26/09 3:33 PM, Hodgess, Erin wrote:
> This is getting weird:
> [erin at tp-login2 ~]$  swift-osg-ress-site-catalog --engage-verified
> -bash: swift-osg-ress-site-catalog: command not found
> Erin M. Hodgess, PhD
> Associate Professor
> Department of Computer and Mathematical Sciences
> University of Houston - Downtown
> mailto: hodgesse at uhd.edu
> -----Original Message-----
> From: hockyg at gmail.com on behalf of Glen Hocky
> Sent: Fri 6/26/2009 3:24 PM
> To: Hodgess, Erin
> Cc: Michael Wilde; Melinda Chin; Swift User Discussion List
> Subject: Re: [swift-user] List of OSG sites
> It's likely this error can be fixed by the same thing Zhao did to get condor
> working last week (since the command works for me). Try putting @osg and
> +osg-client into your ~/.soft file and then resetting up by either logging
> back in or typing "resoft;source ~/.bashrc"
> for reference, here is my ~/.soft file
> @python-2.5
> +java-sun
> +osg-client
> +maui
> +torque
> +R
> +matlab-7.7
> +apache-ant
> +gx-map
> @osg
> @default
> @globus-4
> On Fri, Jun 26, 2009 at 3:20 PM, Hodgess, Erin <HodgessE at uhd.edu> wrote:
>  >  I'm having trouble with the swift-osg-ress-site-catalog command:
>  > [erin at tp-login2 swift]$  swift-osg-ress-site-catalog --engage-verified
>  > Neither the environment variable CONDOR_CONFIG,
>  > /etc/condor/, nor ~condor/ contain a condor_config source.
>  > Either set CONDOR_CONFIG to point to a valid config source,
>  > or put a "condor_config" file in /etc/condor or ~condor/
>  > Exiting.
>  > <config>
>  > </config>
>  > Any help is much appreciated.
>  > Thanks,
>  > Erin
>  > Associate Professor
>  > From: swift-user-bounces at ci.uchicago.edu on behalf of Michael Wilde
>  > Sent: Fri 6/26/2009 2:14 PM
>  > To: Melinda Chin
>  > Cc: Swift User Discussion List
>  >  From a practical point of view, you can get the sites in the OSG
>  > "engagement" VO using this Swift command, which returns the list as a
>  > sites.xml file:
>  > That command also has options for getting sites from other VOs
>  >    swift-osg-ress-site-catalog --vo=osg
>  > On 6/26/09 2:04 PM, Melinda Chin wrote:
>  > > Here's what I think is a simple question but can't find the answer to?
>  > > Where can I find a list of all the osg sites?
>  > > Thank you,
>  > > Melinda Chin
>  > > _______________________________________________
>  > > Swift-user mailing list
>  > > Swift-user at ci.uchicago.edu
>  > > http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
More information about the Swift-user
