[swift-user] List of OSG sites
Glen Hocky hockyg at uchicago.edu
Fri Jun 26 16:17:10 CDT 2009
I never claimed the "condor_status" command works. but with my setup
[hockyg at communicado ~]$ swift-osg-ress-site-catalog | head
<config>
  <!-- FNAL_DZEROOSG_1 -->
  <pool handle="FNAL_DZEROOSG_1" >
    <gridftp  url="gsiftp://d0cabosg1.fnal.gov/jobmanager-pbs/" />
    <jobmanager universe="vanilla" url="d0cabosg1.fnal.gov/jobmanager-pbs"
major="2" />
    <workdirectory >/grid/data/engage/tmp/FNAL_DZEROOSG_1</workdirectory>
  </pool>
  <!-- SBGrid-Harvard-Exp -->
On Fri, Jun 26, 2009 at 3:59 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> Doesn't work.
> My .soft:
> @default
> @globus-4
> +java-sun
> +torque
> +maui
> +condor
> @osg
> +osg-client
> [hategan at tp-login2 ~]$ condor_status
> Neither the environment variable CONDOR_CONFIG,
> /etc/condor/, nor ~condor/ contain a condor_config source.
> Either set CONDOR_CONFIG to point to a valid config source,
> or put a "condor_config" file in /etc/condor or ~condor/
> Exiting.
> On Fri, 2009-06-26 at 15:41 -0500, Michael Wilde wrote:
> > If you added your swift/bin directory to your path manually, when you
> > run resoft you may loose that and need to do it again.
> > On 6/26/09 3:33 PM, Hodgess, Erin wrote:
> > > This is getting weird:
> > > [erin at tp-login2 ~]$  swift-osg-ress-site-catalog --engage-verified
> > > -bash: swift-osg-ress-site-catalog: command not found
> > > Erin M. Hodgess, PhD
> > > Associate Professor
> > > Department of Computer and Mathematical Sciences
> > > University of Houston - Downtown
> > > mailto: hodgesse at uhd.edu
> > > -----Original Message-----
> > > From: hockyg at gmail.com on behalf of Glen Hocky
> > > Sent: Fri 6/26/2009 3:24 PM
> > > To: Hodgess, Erin
> > > Cc: Michael Wilde; Melinda Chin; Swift User Discussion List
> > > Subject: Re: [swift-user] List of OSG sites
> > > It's likely this error can be fixed by the same thing Zhao did to get
> condor
> > > working last week (since the command works for me). Try putting @osg
> and
> > > +osg-client into your ~/.soft file and then resetting up by either
> logging
> > > back in or typing "resoft;source ~/.bashrc"
> > > for reference, here is my ~/.soft file
> > > @python-2.5
> > > +java-sun
> > > +osg-client
> > > +maui
> > > +torque
> > > +R
> > > +matlab-7.7
> > > +apache-ant
> > > +gx-map
> > > @osg
> > > @default
> > > @globus-4
> > > On Fri, Jun 26, 2009 at 3:20 PM, Hodgess, Erin <HodgessE at uhd.edu>
> wrote:
> > >  >  I'm having trouble with the swift-osg-ress-site-catalog command:
> > >  > [erin at tp-login2 swift]$  swift-osg-ress-site-catalog
> --engage-verified
> > >  > Exiting.
> > >  > <config>
> > >  > </config>
> > >  > Any help is much appreciated.
> > >  > Thanks,
> > >  > Erin
> > >  > Associate Professor
> > >  > From: swift-user-bounces at ci.uchicago.edu on behalf of Michael Wilde
> > >  > Sent: Fri 6/26/2009 2:14 PM
> > >  > To: Melinda Chin
> > >  > Cc: Swift User Discussion List
> > >  >  From a practical point of view, you can get the sites in the OSG
> > >  > "engagement" VO using this Swift command, which returns the list as
> a
> > >  > sites.xml file:
> > >  > That command also has options for getting sites from other VOs
> > >  >    swift-osg-ress-site-catalog --vo=osg
> > >  > On 6/26/09 2:04 PM, Melinda Chin wrote:
> > >  > > Here's what I think is a simple question but can't find the answer
> to?
> > >  > > Where can I find a list of all the osg sites?
> > >  > > Thank you,
> > >  > > Melinda Chin
> > >  > > _______________________________________________
> > >  > > Swift-user mailing list
> > >  > > Swift-user at ci.uchicago.edu
> > >  > > http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20090626/a9273f34/attachment.html>
More information about the Swift-user mailing list
