[Swift-user] Running on Teraport
Alex Moore
amoore2 at uchicago.edu
Mon Jun 22 13:10:48 CDT 2009
Thanks, that got it running. I get a different error message now though:
Execution failed:
Exception in wormanalysis
Arguments: [home/amoore2/Work/Data/070326.tif,
home/amoore2/Work/Save/Ang-Def.0006.dat,
home/amoore2/Work/Save/Props.0006.dat]
Host: localhost
Directory: wormanalysis-20090622-1303-7z3h1d62/jobs/0/wormanalysis-0mumlmcj
stderr.txt
stdout.txt
Caused by:
Cannot submit job: java.io.IOException: qsub: not found
The program loads an image file from my CI account as input and
outputs two .dat files to a directory on my CI account as well- I
don't know if it might be something in my code that is causing this.
Thanks.
-Alex
On Mon, Jun 22, 2009 at 12:54 PM, Zhao Zhang<zhaozhang at uchicago.edu> wrote:
> Hi, Alex
> # sitename transformation path INSTALLED platform profiles
> pbs wormanalysis /home/amoore2/work/run_wormanalysis.sh
> INSTALLED INTEL32::LINUX null
> change the "pbs" above to localhost.
> That "sitename" field should be the same as the <pool handle> in sites.xml
> best
> zhao
> Alex Moore wrote:
>> Trying to run a job on Teraport. Logged into tp-login.ci.uchicago.edu.
>> Use the following entries for sites.xml and tc.dat:
>> <pool handle="localhost">
>> <gridftp url="local://localhost" />
>> <execution provider="pbs" url="none" />
>> <workdirectory >/var/tmp</workdirectory>
>> <profile namespace="karajan" key="jobThrottle">0</profile>
>> </pool>
>> My swift program call an app named wormanalysis that is on my ci
>> account. Runs fine locally. Mike Wilde said that changing the
>> "<execution provider=" to pbs instead of localhost should work. Got
>> the following error message:
>> Execution failed:
>> Could no find any valid host for the task "Task( type=UNKNOWN,
>> identity=urn:cog-1245692325277)" with constraints {filenames=
>> [Ljava.lang.Sting;@15f98bd, trfqn=wormanalysis,
>> filecache=0rg.griphyn.vdl.karajan.lib.cache.CacheMapAdapter at 15f98f9,
>> tr=wormanalysis}
>> Any help would be appreciated. Thanks.
>> -Alex
>> Swift-user mailing list
>> Swift-user at ci.uchicago.edu
>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
More information about the Swift-user
