[Swift-user] Running on Teraport
Zhao Zhang
zhaozhang at uchicago.edu
Mon Jun 22 12:54:26 CDT 2009
Hi, Alex
# sitename transformation path INSTALLED platform profiles
pbs wormanalysis /home/amoore2/work/run_wormanalysis.sh
INSTALLED INTEL32::LINUX null
change the "pbs" above to localhost.
That "sitename" field should be the same as the <pool handle> in sites.xml
best
zhao
Alex Moore wrote:
> Trying to run a job on Teraport. Logged into tp-login.ci.uchicago.edu.
> Use the following entries for sites.xml and tc.dat:
> <pool handle="localhost">
> <gridftp url="local://localhost" />
> <execution provider="pbs" url="none" />
> <workdirectory >/var/tmp</workdirectory>
> <profile namespace="karajan" key="jobThrottle">0</profile>
> </pool>
> My swift program call an app named wormanalysis that is on my ci
> account. Runs fine locally. Mike Wilde said that changing the
> "<execution provider=" to pbs instead of localhost should work. Got
> the following error message:
> Execution failed:
> Could no find any valid host for the task "Task( type=UNKNOWN,
> identity=urn:cog-1245692325277)" with constraints {filenames=
> [Ljava.lang.Sting;@15f98bd, trfqn=wormanalysis,
> filecache=0rg.griphyn.vdl.karajan.lib.cache.CacheMapAdapter at 15f98f9,
> tr=wormanalysis}
> Any help would be appreciated. Thanks.
> -Alex
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
More information about the Swift-user
