[Swift-user] Swift on local resources
Mihael Hategan hategan at mcs.anl.gov
Mon Jun 15 14:42:25 CDT 2009
On Mon, 2009-06-15 at 12:49 -0400, Andriy Fedorov wrote:
> On Sat, Jun 13, 2009 at 7:12 AM, Mihael Hategan<hategan at mcs.anl.gov> wrote:
> > If you want to use password authentication, remove the key and
> > passphrase lines and add <host>.password=xxx.
> ...and add
> host.site.type=password
Ooops!
> What you suggested is actually working for me, thank you for the
> clarification. But having password saved in plain text is not a very
> comfortable option.
No, it isn't. Unless there is no access to the machine from the outside,
in which case it's pretty much equivalent (if not better) than
host-based authentication.
> Please consider this a feature request: it would be great if for the
> SSH authentication, the user was asked for a password once, and then
> the password (or its hash) was stored securely, and authentication was
> done transparently.
Well... there is such a feature in cog, but I don't think it's enabled
in swift. It's a matter of SSH not having been used much. So I think we
can work something out.
> I am even willing to enter my password each time I submit a script,
> rather than having it saved as text on a filesystem!
That's likely what will happen. There is no "secure way" I know of for
storing retrievable passwords on a shared disk.
>  But I am not
> given an option to do it like this at this point.
> > However, in some cases being asked by ssh for a password may mean
> > "keyboard interactive authentication" which is not the same as
> > "username/password authentication" and may not work with the ssh
> > provider. Do an ssh -v and you'll see the list of authentication methods
> > that the server allows.
> >> AF
> >> On Fri, Jun 12, 2009 at 4:04 PM, Allan
> >> Espinosa<aespinosa at cs.uchicago.edu> wrote:
> >> > Hi Andriy and Mike,
> >> > here is my example ~/.ssh/auth.defaults for executing jobs on
> >> > tp-login1.ci.uchicago.edu:
> >> > [aespinosa at tp-login2 ~]$ cat .ssh/auth.defaults
> >> > tp-login1.ci.uchicago.edu.type=key
> >> > tp-login1.ci.uchicago.edu.username=aespinosa
> >> > tp-login1.ci.uchicago.edu.key=/home/aespinosa/.ssh/id_dsa
> >> > tp-login1.ci.uchicago.edu.passphrase=XXXXXXXX
> >> > We have used falkon and coasters before for multi-core configurations.
> >> >  but for a single multi-core machine, i believe you can get away with
> >> > having multiple entries of the same host in the sites.xml file using
> >> > the ssh-provider.
> >> > ie:
> >> > <config>
> >> > <pool handle="CORE0">
> >> >   <execution provider="ssh"... />
> >> > </pool>
> >> > <pool handle="CORE1">
> >> > </pool>
> >> > </config>
> >> > 2009/6/12 Michael Wilde <wilde at mcs.anl.gov>:
> >> >> Ah, very cool. Im eager to get more user experience feedback on multicore
> >> >> use.
> >> >> So I will try to hunt down my examples of .ssh configs.
> >> >> Also, Allan Espinosa used this recently. Allan, can you post details and
> >> >> examples?
> >> >> Thanks!
> >> >> Mike
> >> >> On 6/12/09 2:06 PM, Andriy Fedorov wrote:
> >> >>> Michael,
> >> >>> Thank you for the advice, I will look into this. This is very helpful.
> >> >>> I had an impression Lava is not included in the list of schedulers
> >> >>> supported out of the box, but wanted to check.
> >> >>> Just a clarification -- I need to access two different types of local
> >> >>> resources. Cluster (via Lava or Condor) is one, but for the multicore
> >> >>> nodes we have on the network, which are not part of cluster, the only
> >> >>> option is to use ssh.
> >> >>> AF
> >> >>> On Fri, Jun 12, 2009 at 2:52 PM, Michael Wilde<wilde at mcs.anl.gov> wrote:
> >> >>>> Andriy,
> >> >>>> Ben or Mihael may have better ideas, but I offer my thoughts below.
> >> >>>> On 6/12/09 1:18 PM, Andriy Fedorov wrote:
> >> >>>>> Hi,
> >> >>>>> I am trying to set up Swift with the local cluster and non-cluster
> >> >>>>> resources in our lab. Here some configuration details.
> >> >>>>> Due to technical problems, passphrase login is not possible for the
> >> >>>>> nodes on local network, and I need to enter password each time.
> >> >>>>> For the cluster, I was able to set up passphrase login for the head
> >> >>>>> node. The cluster is running Lava and Condor schedulers at the same
> >> >>>>> time, but Lava should be used if possible.
> >> >>>>> Two questions:
> >> >>>>> (1) is it possible to configure Swift to talk to Lava scheduler?
> >> >>>> Making Swift talk to a new scheduler means writing a new CoG provider (in
> >> >>>> Java). You can likely use an existing "data" provider like "local"; you
> >> >>>> could model the "execution" provider after the "PBS" provider. How hard
> >> >>>> this
> >> >>>> is depends on how close Lava is to PBS in nature. (I dont know it). And
> >> >>>> the
> >> >>>> provider interface you need to code to is not well documented afaik.
> >> >>>> I would try the Condor provider. While that provider is less mature and
> >> >>>> tested than others, it should work, and if it doesnt, we should try to
> >> >>>> fix
> >> >>>> it.
> >> >>>> If possible, make sure a simple condor_submit hello-world works for you
> >> >>>> first.
> >> >>>> Run swift on the head/login node; use the "local" data provider.
> >> >>>> Another route is to use Falkon, but that will be harder and its less
> >> >>>> supported, so I suggest against this until easier routes are exhausted.
> >> >>>> I dont think that ssh will get you far, as to leverage the cluster I
> >> >>>> think
> >> >>>> you'd need to describe each worker node with a separate sites.xml entry.
> >> >>>> Thats fine in principle, but a bit awkward, and may have scheduling
> >> >>>> issues
> >> >>>> (ie if ssh hangs or dies when you dont own the node).
> >> >>>> Save ssh as another last resort; I suggest trying Condor first.
> >> >>>> If needed, people who used ssh recently can send you the info below.
> >> >>>> - Mike
> >> >>>>> (2) I am following the instructions on setting up ssh site provider to
> >> >>>>> use nodes on the local network.
> >> >>>>>  (2.1) do I need to set up auth.defaults even if I have ssh-agent
> >> >>>>> running, and can ssh to the remote node without being asked for
> >> >>>>> password?
> >> >>>>>  (2.2.) can anybody give me more detailed instructions on how to set
> >> >>>>> up auth.defaults? I cannot make it work.
> >> >>>>> Thanks
> >> >>>>> Andriy Fedorov
> >> >>>>> _______________________________________________
> >> > Allan M. Espinosa <http://allan.88-mph.net/blog>
> >> > PhD student, Computer Science
> >> > University of Chicago <http://people.cs.uchicago.edu/~aespinosa>
> >> Swift-user mailing list
> >> Swift-user at ci.uchicago.edu
> >> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
More information about the Swift-user mailing list
