[Swift-user] Swift on local resources
    Andriy Fedorov
    fedorov at cs.wm.edu
    Mon Jun 15 11:49:32 CDT 2009
On Sat, Jun 13, 2009 at 7:12 AM, Mihael Hategan<hategan at mcs.anl.gov> wrote:
> If you want to use password authentication, remove the key and
> passphrase lines and add <host>.password=xxx.
...and add
host.site.type=password
What you suggested is actually working for me, thank you for the
clarification. But having password saved in plain text is not a very
comfortable option.
Please consider this a feature request: it would be great if for the
SSH authentication, the user was asked for a password once, and then
the password (or its hash) was stored securely, and authentication was
done transparently.
I am even willing to enter my password each time I submit a script,
rather than having it saved as text on a filesystem! But I am not
given an option to do it like this at this point.
> However, in some cases being asked by ssh for a password may mean
> "keyboard interactive authentication" which is not the same as
> "username/password authentication" and may not work with the ssh
> provider. Do an ssh -v and you'll see the list of authentication methods
> that the server allows.
>> AF
>> On Fri, Jun 12, 2009 at 4:04 PM, Allan
>> Espinosa<aespinosa at cs.uchicago.edu> wrote:
>> > Hi Andriy and Mike,
>> > here is my example ~/.ssh/auth.defaults for executing jobs on
>> > tp-login1.ci.uchicago.edu:
>> > [aespinosa at tp-login2 ~]$ cat .ssh/auth.defaults
>> > tp-login1.ci.uchicago.edu.type=key
>> > tp-login1.ci.uchicago.edu.username=aespinosa
>> > tp-login1.ci.uchicago.edu.key=/home/aespinosa/.ssh/id_dsa
>> > tp-login1.ci.uchicago.edu.passphrase=XXXXXXXX
>> > We have used falkon and coasters before for multi-core configurations.
>> >  but for a single multi-core machine, i believe you can get away with
>> > having multiple entries of the same host in the sites.xml file using
>> > the ssh-provider.
>> > ie:
>> > <config>
>> > <pool handle="CORE0">
>> >   <execution provider="ssh"... />
>> > </pool>
>> > <pool handle="CORE1">
>> > </pool>
>> > </config>
>> > 2009/6/12 Michael Wilde <wilde at mcs.anl.gov>:
>> >> Ah, very cool. Im eager to get more user experience feedback on multicore
>> >> use.
>> >> So I will try to hunt down my examples of .ssh configs.
>> >> Also, Allan Espinosa used this recently. Allan, can you post details and
>> >> examples?
>> >> Thanks!
>> >> Mike
>> >> On 6/12/09 2:06 PM, Andriy Fedorov wrote:
>> >>> Michael,
>> >>> Thank you for the advice, I will look into this. This is very helpful.
>> >>> I had an impression Lava is not included in the list of schedulers
>> >>> supported out of the box, but wanted to check.
>> >>> Just a clarification -- I need to access two different types of local
>> >>> resources. Cluster (via Lava or Condor) is one, but for the multicore
>> >>> nodes we have on the network, which are not part of cluster, the only
>> >>> option is to use ssh.
>> >>> AF
>> >>> On Fri, Jun 12, 2009 at 2:52 PM, Michael Wilde<wilde at mcs.anl.gov> wrote:
>> >>>> Andriy,
>> >>>> Ben or Mihael may have better ideas, but I offer my thoughts below.
>> >>>> On 6/12/09 1:18 PM, Andriy Fedorov wrote:
>> >>>>> Hi,
>> >>>>> I am trying to set up Swift with the local cluster and non-cluster
>> >>>>> resources in our lab. Here some configuration details.
>> >>>>> Due to technical problems, passphrase login is not possible for the
>> >>>>> nodes on local network, and I need to enter password each time.
>> >>>>> For the cluster, I was able to set up passphrase login for the head
>> >>>>> node. The cluster is running Lava and Condor schedulers at the same
>> >>>>> time, but Lava should be used if possible.
>> >>>>> Two questions:
>> >>>>> (1) is it possible to configure Swift to talk to Lava scheduler?
>> >>>> Making Swift talk to a new scheduler means writing a new CoG provider (in
>> >>>> Java). You can likely use an existing "data" provider like "local"; you
>> >>>> could model the "execution" provider after the "PBS" provider. How hard
>> >>>> this
>> >>>> is depends on how close Lava is to PBS in nature. (I dont know it). And
>> >>>> the
>> >>>> provider interface you need to code to is not well documented afaik.
>> >>>> I would try the Condor provider. While that provider is less mature and
>> >>>> tested than others, it should work, and if it doesnt, we should try to
>> >>>> fix
>> >>>> it.
>> >>>> If possible, make sure a simple condor_submit hello-world works for you
>> >>>> first.
>> >>>> Run swift on the head/login node; use the "local" data provider.
>> >>>> Another route is to use Falkon, but that will be harder and its less
>> >>>> supported, so I suggest against this until easier routes are exhausted.
>> >>>> I dont think that ssh will get you far, as to leverage the cluster I
>> >>>> think
>> >>>> you'd need to describe each worker node with a separate sites.xml entry.
>> >>>> Thats fine in principle, but a bit awkward, and may have scheduling
>> >>>> issues
>> >>>> (ie if ssh hangs or dies when you dont own the node).
>> >>>> Save ssh as another last resort; I suggest trying Condor first.
>> >>>> If needed, people who used ssh recently can send you the info below.
>> >>>> - Mike
>> >>>>> (2) I am following the instructions on setting up ssh site provider to
>> >>>>> use nodes on the local network.
>> >>>>>  (2.1) do I need to set up auth.defaults even if I have ssh-agent
>> >>>>> running, and can ssh to the remote node without being asked for
>> >>>>> password?
>> >>>>>  (2.2.) can anybody give me more detailed instructions on how to set
>> >>>>> up auth.defaults? I cannot make it work.
>> >>>>> Thanks
>> >>>>> Andriy Fedorov
>> >>>>> _______________________________________________
>> > Allan M. Espinosa <http://allan.88-mph.net/blog>
>> > PhD student, Computer Science
>> > University of Chicago <http://people.cs.uchicago.edu/~aespinosa>
>> Swift-user mailing list
>> Swift-user at ci.uchicago.edu
>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
More information about the Swift-user
