[Swift-user] oops failures on OSG
Mihael Hategan
hategan at mcs.anl.gov
Fri Feb 20 16:10:30 CST 2009
I'm seeing this in the logs:
No status file was found. Check the shared filesystem on UCSDT2-B
For the short term I suggest commenting out that site in the
sites file.
Mihael
----- Zhengxiong Hou <zhengxiongh at uchicago.edu> wrote:
> Hi,
> We encountered some failures when running oops within Engage VO or
> OSG VO on OSG by swift. Please have a look.
> The logs ( oops7-20090219-1827-6gqbuh81.0.rlog,
> oops7-20090219-1827-6gqbuh81.log, oops7-20090219-1827-6gqbuh81.d) have
> been saved to Ben's swift-logs directory.
> And the following is the standard output information when running it
> within Engage VO.
> > Progress: Submitted:27 Active:22 Finished successfully:51
> > Progress: Submitted:27 Active:21 Finished successfully:52
> > Progress: Submitted:26 Active:22 Finished successfully:52
> > Failed to transfer wrapper log from
> > oops7-20090219-1827-6gqbuh81/info/o on UCSDT2-B
> > Progress: Submitted:26 Active:21 Failed:1 Finished successfully:52
> > Execution failed:
> > Exception in runoops:
> > Arguments: [input/fasta/T1di2.fasta, input/secseq/T1di2.secseq,
> > input/native/T1di2.pdb, output/T1di2.26.pdt, output/T1di2.26.rmsd, 26,
> > TEMP UPDATE INTERVAL = 10, SMOOTH DEVIATION COEFFICIENT = 0.80001]
> > Host: UCSDT2-B
> > Directory: oops7-20090219-1827-6gqbuh81/jobs/o/runoops-on95pu6j
> > stderr.txt:
> > stdout.txt:
> Thanks!
> Zhengxiong
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
More information about the Swift-user
