[Swift-user] oops failures on OSG
Mats Rynge
rynge at renci.org
Fri Feb 20 17:59:38 CST 2009
On Fri, Feb 20, 2009 at 04:10:30PM -0600, Mihael Hategan wrote:
> I'm seeing this in the logs:
> No status file was found. Check the shared filesystem on UCSDT2-B
This reminds me to bring up an issue other users have had on UCSDT2 and
similar sites on OSG. UCSDT2 and UCSDT2-B are two interfaces to the
same cluster (shared filesystem is the same). If you give those as two
separate sites to Swift, will Swift be confused about the data caching?
That is, is the data caching directory named the same on all sites in a
run?
There are other clusters on OSG with multiple gatekeepers.
Mats Rynge
Renaissance Computing Institute <http://www.renci.org>
More information about the Swift-user
