[Swift-user] mapper for internet resources
Michael Wilde wilde at mcs.anl.gov
Sat Feb 7 10:44:41 CST 2009
Also:
 >> Writing files will need to be to the machine where swift is running
from.
You can write files to any gridftp server by mapping to a gsiftp:// URI,
as with input.
As far as I understand, the gsiftp provider can support: http, https,
ftp, and gsiftp URIs, with the gridftp data provider, <gridftp> in
sites.xml.
If the uri works with globus-url-copy I think it will work with the
gridftp provider.
I think that Swift can also accept other providers from the CoG toolkit,
such as scp and webdav. See
   http://www.ci.uchicago.edu/swift/guides/userguide.php#id2745803
for using scp.  We should test and document hos to use webdav.
Perhaps Mihael or Ben can verify and clarify the above.
- Mike
On 2/7/09 10:24 AM, Michael Wilde wrote:
> Uri, I took the liberty of replying via swift-user.
> Thats the best place to send these questions.
> Swift can do this already, as below.
> A mapper can map an ordinary file as a local file name (relative or
> absolute), or an http:// or gsiftp:// URI. (Perhaps others a well, I
> think, eg, ftp:// depending on the underlying CoG and Globus APIs.)
> - Mike
> type file;
> app (file f) afniapp (file u) { cat @u stdout=@f; }
> file mydata <"http://www.ci.uchicago.edu/~wilde/mydata.txt">;
> file output <"gotit.txt">;
> output = afniapp(mydata);
> On 2/7/09 3:44 AM, Uri Hasson wrote:
>> Hi all,
>> Is there currently a way to use swift mappers to access internet
>> resources?
>> That is, rather than have a file as input, have a "url" mapper than
>> can manage something like this:
>> AFNI_obj normalized<simple_url_mapper;
>> prefix=@strcat("http://www.mysite.com/somepath/audioTScat_nrmlzdPerChng.",subject,"+orig.")>;.
>> This would enable us to run a swift script on inputs from other file
>> systems (for Read processes).
>> Writing files will need to be to the machine where swift is running from.
>> Best,
>> Uri
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
More information about the Swift-user mailing list
