[Swift-user] mixing gram execution and local filesystem providers
Mihael Hategan hategan at mcs.anl.gov
Tue Feb 3 18:34:15 CST 2009
On Wed, 2009-02-04 at 00:11 +0000, Ben Clifford wrote:
> On Tue, 3 Feb 2009, Allan Espinosa wrote:
> > Does this mean that the "cp" calls fail after a while?
> It means something failed. In the log, I see this:
> > org.globus.cog.abstraction.impl.common.task.InvalidSecurityContextException:
> Invalid GSSCredentials
> and
> > Caused by: GSSException: Defective credential detected [Caused by:
> > [JGLOBUS-5] Proxy file
> > (/home/aespinosa/.globus/job/tp-grid1.ci.uchicago.edu/11827.1233702664/x509_up)
> not found.]
> which is a strange looking error.
> I'd expect credential errors if your proxy just expired (please paste the
> output of grid-proxy-info from the same session that you ran this swift
> invocation from, if you still have it).
> But I wouldn't expect the error message to have a path to a credential
> inside what looks like the remote job directory.
Unless it's a delegated credential and the error happens in a gram job?
More information about the Swift-user mailing list
