[Swift-user] mixing gram execution and local filesystem providers
    Ben Clifford
    benc at hawaga.org.uk
    Tue Feb  3 18:11:15 CST 2009
On Tue, 3 Feb 2009, Allan Espinosa wrote:
> Does this mean that the "cp" calls fail after a while?
It means something failed. In the log, I see this:
> org.globus.cog.abstraction.impl.common.task.InvalidSecurityContextException:
Invalid GSSCredentials
and
> Caused by: GSSException: Defective credential detected [Caused by:
> [JGLOBUS-5] Proxy file
> (/home/aespinosa/.globus/job/tp-grid1.ci.uchicago.edu/11827.1233702664/x509_up)
not found.]
which is a strange looking error.
I'd expect credential errors if your proxy just expired (please paste the
output of grid-proxy-info from the same session that you ran this swift
invocation from, if you still have it).
But I wouldn't expect the error message to have a path to a credential
inside what looks like the remote job directory.
More information about the Swift-user
