[Swift-user] mixing gram execution and local filesystem providers
Allan Espinosa aespinosa at cs.uchicago.edu
Tue Feb 3 12:20:46 CST 2009
Hi mike
yes it gives a different java environment (but the same for both
submission hosts communicado and tp-login1:
globus-job-run tp-grid1.ci.uchicago.edu /bin/bash -l -c "which java"
SoftEnv 1.6.0: updating your software environment, one moment...
/autonfs/software/linux-rhel4-x86_64/osg-client-1.0.0-r1/jdk1.5/bin/java
vs
 globus-job-run tp-grid1.uchicago.edu /usr/bin/which java
/opt/osg-ce-0.8.0-r1/jdk1.5/bin/java
Update:  I fixed my ~/.soft file and observed that my coaster runs
(gt2:gt2:pbs local filesystem provider)  now work .
-Allan
On Tue, Feb 3, 2009 at 9:20 AM, Michael Wilde <wilde at mcs.anl.gov> wrote:
> Were they submitted from the same cert, with the same cert-to-uid mapping in
> place?
> Its possible that the OSG jobmanager initialization code differentiates
> between OSG VO users and users mapped to their own ID.
> Try running globus-job-run tp-grid1.ci.uchicago.edu /bin/bash -l -c "which
> java", and the same without "-l", from both submission hosts.
> - Mike
> On 2/2/09 2:52 PM, Allan Espinosa wrote:
>> Yes they are the same.  the succesful one was submitted from tp-login1
>> (where tp-grid1 is) and the otherone from communicado.
>> -Allan
>> On Mon, Feb 2, 2009 at 2:48 PM, Ben Clifford <benc at hawaga.org.uk> wrote:
>>> On Mon, 2 Feb 2009, Allan Espinosa wrote:
>>>> yes its the same sites.xml file.  Here is the log of the successful
>>>> gt2:gt2:pbs
>>>> http://www.ci.uchicago.edu/~aespinosa/swift/blast-20090202-1357-98hzn0n1.log
>>> ok. So that is submitted using the same as:
>>> http://www.ci.uchicago.edu/~aespinosa/swift/blast-20090202-1335-pbur79zc.log
>>> with the only difference that you are aware of being that they are
>>> submitted from different machines?
More information about the Swift-user mailing list
