[Swift-user] mixing gram execution and local filesystem providers
Michael Wilde wilde at mcs.anl.gov
Tue Feb 3 09:20:22 CST 2009
Were they submitted from the same cert, with the same cert-to-uid
mapping in place?
Its possible that the OSG jobmanager initialization code differentiates
between OSG VO users and users mapped to their own ID.
Try running globus-job-run tp-grid1.ci.uchicago.edu /bin/bash -l -c
"which java", and the same without "-l", from both submission hosts.
- Mike
On 2/2/09 2:52 PM, Allan Espinosa wrote:
> Yes they are the same.  the succesful one was submitted from tp-login1
> (where tp-grid1 is) and the otherone from communicado.
> -Allan
> On Mon, Feb 2, 2009 at 2:48 PM, Ben Clifford <benc at hawaga.org.uk> wrote:
>> On Mon, 2 Feb 2009, Allan Espinosa wrote:
>>> yes its the same sites.xml file.  Here is the log of the successful gt2:gt2:pbs
>>> http://www.ci.uchicago.edu/~aespinosa/swift/blast-20090202-1357-98hzn0n1.log
>> ok. So that is submitted using the same as:
>> http://www.ci.uchicago.edu/~aespinosa/swift/blast-20090202-1335-pbur79zc.log
>> with the only difference that you are aware of being that they are
>> submitted from different machines?
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
More information about the Swift-user mailing list
