[Swift-user] Why so few nodes ?
Xueyuan Zhou zhouxy at uchicago.edu
Tue Sep 23 13:49:55 CDT 2008
the result is in /home/zhouxy/dic_parser/swift_script4
one thing I noticed is that, when I only use one site, it starts with 2
running jobs, then increases, and finally also reaches 8 running jobs, which
is the same as two sites. So the total time when using one site and two site
is not quite different.
----- Original Message -----
To: "Mihael Hategan" <hategan at mcs.anl.gov>
Cc: "Xueyuan Zhou" <zhouxy at uchicago.edu>; <swift-user at ci.uchicago.edu>
Sent: Tuesday, September 23, 2008 1:25 PM
Subject: Re: [Swift-user] Why so few nodes ?
> On Tue, 23 Sep 2008, Mihael Hategan wrote:
>> May it be because you're using the "fast" queue, which may have a
>> limitation on the maximum number of nodes you can get at one time?
> There is evidence that sending jobs twice as fast (by defining two swift
> sites for teraport) made twice as many jobs run. These would be counter to
> the argument that there is a max node count and supportive of there being
> some long scheduling delay in the LRM, I think.
> I guess increasing the jobThrottle to a larger number would therefore get
> more jobs in the queue and more jobs run, but putting more node on the
> head node.
> Xueyuan, add this line to one of your site definitions: (but not both)
> <profile namespace="karajan" key="jobThrottle">0.5</profile>
> then make a run and send a log.
More information about the Swift-user mailing list
