[Swift-user] Why so few nodes ?
Ben Clifford benc at hawaga.org.uk
Tue Sep 23 12:16:40 CDT 2008
On Tue, 23 Sep 2008, Xueyuan Zhou wrote:
> also noticed there are some free nodes there. I am wondering why I can only
> have about 8 running job (on 4 nodes), and about 20~30 in Q, while dozons of
> nodes are free.
If you have jobs sitting in the queue on teraport then that is something
to do with the way that the queueing system is working on teragrid.
I put graphs here:
http://www.ci.uchicago.edu/~benc/tmp/report-test1M-20080922-2203-gamhpzp1/
It looks like your getting around 8 jobs running at once, which matches up
with your observation in the above quote.
Mihael says this:
> May it be because you're using the "fast" queue, which may have a
> limitation on the maximum number of nodes you can get at one time?
though the queue policy page here:
http://www.ci.uchicago.edu/wiki/bin/view/Teraport/QueuePolicies
does not mention anything about it.
Though the wiki also contractions this from Mihael:
> How do you reach that conclusion? As far as I can tell, by default, one
> job maps to one node (regardless of the number of cores).
by saying:
> Single-processor jobs submitted by a user are paired up on a single node
> to maximize cluster efficiency.
I haven't tried that myself.
More information about the Swift-user mailing list
