[Swift-user] Problem about configuration for swift
Xueyuan Zhou zhouxy at uchicago.edu
Wed Sep 17 14:48:09 CDT 2008
Thanks a lot Ben!
After I installed 0.6 version, it works!
-Xueyuan
----- Original Message -----
To: "Xueyuan Zhou" <zhouxy at uchicago.edu>
Cc: <swift-user at ci.uchicago.edu>
Sent: Wednesday, September 17, 2008 2:31 PM
Subject: Re: [Swift-user] Problem about configuration for swift
> On Wed, 17 Sep 2008, Xueyuan Zhou wrote:
>> 2008.09.17 14:20:08.306 CDT: [FATAL ERROR] You forgot to set
>> -Dpegasus.home=$PEGASUS_HOME!
> I've seen this error when both of the following conditions are true:
> i) Pegasus is installed on the same machine
> ii) You are using an old version of swift (build prior to cog r2007,
> 2008-05-12)
> Are the above true for you? If so, move to a recent version of swift, eg
> 0.6 which is the latest release.
More information about the Swift-user mailing list
