[Swift-user] Problem about configuration for swift
Ben Clifford benc at hawaga.org.uk
Wed Sep 17 14:31:38 CDT 2008
On Wed, 17 Sep 2008, Xueyuan Zhou wrote:
> 2008.09.17 14:20:08.306 CDT: [FATAL ERROR] You forgot to set
> -Dpegasus.home=$PEGASUS_HOME!
I've seen this error when both of the following conditions are true:
 i) Pegasus is installed on the same machine
 ii) You are using an old version of swift (build prior to cog r2007,
2008-05-12)
Are the above true for you? If so, move to a recent version of swift, eg
0.6 which is the latest release.
More information about the Swift-user mailing list
