[Swift-user] Re: swift guts doc with many diagrams and graphs
Alina Bejan abejan at ci.uchicago.edu
Tue Oct 14 10:28:35 CDT 2008
Alright -- I am not able to re-create the problem, so might have been a problem of mine. It does compile now fine with 0.6, but I am facing other wrapper file tranferring problems now (which I did not have yesterday with 0.5).
If the problem persists, I will get back with another email.
Alina
Michael Wilde wrote:
> I think its spelled readData(), or was there another problem with it?
> - Mike
> On 10/14/08 9:34 AM, Alina Bejan wrote:
>> yes, it worked, thanks.
>> One more problem I noticed: 'readdata' does not work under Swift 0.6
>> (so I went back to use Swift 0.5). This might be a known problem, but
>> thought I'd mention it.
>> Alina
>> Ben Clifford wrote:
>>> Try log-processing r2293 (type 'svn update' in the log-processing
>>> directory and check that it says you have r2293 or higher)
>>> That fixes the problem for me.
>>> On Mon, 13 Oct 2008, Alina Bejan wrote:
>>>> Ok -- I am continuing this discussion on the user list.
>>>> Here's where I put the .log file and the output of the
>>>> swift-plot-log command
>>>> on this file.
>>>> http://www.ci.uchicago.edu/~abejan/swift-logs/
>>>> Alina
>>>>>> Please tell me if the instructions below are still accurate, or if
>>>>>> anything
>>>>>> changed -- basically the 'report-abc' directory  fails to being
>>>>>> created.
>>>>> Probably the thing to do is make a report to eithe r this or the
>>>>> users list
>>>>> with the following: a URL or filesystem path where we can see the
>>>>> log file;
>>>>> the output of running swoft-plot-log.
>>>>> This guide isn't intended to contain basic user instructions for
>>>>> that - the
>>>>> page that you looked at before (with the below instructions) is.
>>>>> Those
>>>>> instructions that you pasted below should still work.
>>>>>> "On a computer such as communicado, type:
>>>>>>  svn co https://svn.ci.uchicago.edu/svn/vdl2/log-processing
>>>>>>  cd log-processing/bin
>>>>>>  export PATH=$(pwd):$PATH
>>>>>>  swift-plot-log mylog-01234456-8922-abcdef.log
>>>>>> This will give you a directory report-mylog-01234456-8922-abcdef/
>>>>>> I usually then
>>>>>> mv report-mylog-01234456-8922-abcdef ~benc/public_html/
>>>>>> so that I can view it with a web browser at
>>>>>> http://www.ci.uchicago.edu/~benc/report-mylog-01234456-8922-abcdef/
>> Swift-user mailing list
>> Swift-user at ci.uchicago.edu
>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
More information about the Swift-user mailing list
